Chat Area => General Discussion Area => Topic started by: nigsey1600e on 21 September 2006, 17:58:32
Hi to all
just thought i would let you know how i got on today changing my auto gearbox oil today
Had a day off work today as i am going on holiday tomorrow to weymouth so i thought i would give my megga a good going over cleaning etc, Anyway got carried away and ended up doing oil and all the fillters engine and diff (sucked out the diff oil with a old bike pump very messy) and i thought sod it i will have a go the same way with the auto box (even more messy and have not got a nasty burn on my elbow from the cats >:() sucked most of the oil i could and replaced with new filled up till it run runs out with engine running on level ground. cleaned my self up and went for a spin.
I can not now belive the differance in the gearbox now the changes under normal driving are totally unnoticeable and not much differant under load the whole drive now feels much smoother i am really pleased with the rsults and strongly recommend everbody doing this very easy to do and the results are amazing :)
cheers neil
Not starting-off another oil thread, which ATF did you use?
Good to hear it has such a positive result for you. :)
Gearbox and diff oil.... truly foul smelling stuff! >:(
I have to do the same to mine, I will drop the sump though and change the filter while I am at it.
Really not a job I am looking forward to...
duckhams atf 111 £5.49 a litre in my local factors only used that as that was all they had enough of
the diff oil was a real pain to pump out i would recomend anybody else to do it warm.
i did think about dropping the gearbox sump and changing the fiters although at only 80k i did not think it nessary and my old oil came out nice clean still red
Good price, that... they are usally £8-£9 per litre at Petrol Stations, and not available on Trade Club. Did you check how much you managed to pump out? Or alternatively how much did you need to add? Would be interesting to check this compared to the full capacity 4.4L.
Interesting....
http://www.trueshopping.co.uk/product/Sealey_Oil_Suction_Syringe/21671/21671.html
(http://img84.imageshack.us/img84/1091/ak46ek3.jpg) (http://imageshack.us)
Interesting....
Now that does look handy, and only 12 quid! :o
I am tempted... changing gear oil without dropping the sump... hmmm.... it won't get out the ATF from the small sump though. I didn't get a reply to my question regarding the capacity of old ATF he managed to extract this way (or how much he had to top it back up).
Even if you got most of it out before dropping the sump, it'd still be a whole lot less messy.
So I have to pay for both the syringe AND the gasket set? hmmm... ;D
But yes it does make sense.
Practical Classics did a product test on fluid extractors this month. The best buy was from www.screwfix.com and cost £39.99 (item no. 21663) It's a bit dearer than the Sealey one but could be worth a look too. They also recommended the Draper 73291 but bloody expensive at £73.45! Mind you, it can also be used for draining engine oil, bleeding brakes etc.
Cheers Jim
You dont need any of that expensive rubbish.
Equipment
20ft Garden Hose
One wife/Girlfriend
To do the job place one end of garden house in gearbox and the other in wifes/girlfriend mouth. Now I always find the wife/girlfriend will ask "whats this for" just tell them because you love them so much you thought you would get them a nice drink and to save having to get up and down the other end is in the bottle. Now because there is 20ft of hose that should be enough to empty the gearbox without it reaching the wifes/girlfriends mouth but do keep an eye out just in case or divorce or prison could follow. PS I always keep a bottle of my wifes favorite tipple handy as a reward for a job well done ;)
Equipment
20ft Garden Hose
One wife/Girlfriend
As long as she remembers to suck and not blow. ;D
Equipment
20ft Garden Hose
One wife/Girlfriend
pmsl ;D
Equipment
20ft Garden Hose
One wife/Girlfriend
To cure this I find a quick flick of the adams apple normally works. you can use this in other situations as well ;)
Equipment
20ft Garden Hose
One wife/Girlfriend
;D ;D ;D
