Omega Help Area => Omega General Help => Topic started by: i260 on 27 May 2009, 13:46:34
Title: Tuning for the 2.6 V6
Post by: i260 on 27 May 2009, 13:46:34
Is this a bit lost cause?
The old 2.5 had the options of the enlarged throttle body, gsi or 3.0 cams for 200+ bhp.
Are there similar easy upgrades for the 2.6? Do the 3.2 inlet cams work for the 2.6 like the 3.0's did in the 2.5? Did the 2.6 Vectra GSi have anything special over the Omega engine?
Also, are there any easy airbox mods that can be performed?
I guess that the heads could be done but only if the gaskets go first!
Finally, what do folks do for re-mapping? Any preferred suppliers?
Cheers!
 8-)
Title: Re: Tuning for the 2.6 V6
Post by: Martin_1962 on 27 May 2009, 14:09:02
Here goes.
3.0 inlet divider
inlet ports matched to divider
3.0 cams
Looking at about 200bhp
See my car and Mike Dundees car
Post by: i260 on 30 May 2009, 14:15:37
Got any pics of the inlet divider you are referring to as there are so many bits there!
I presume that the 3.0 and 3.2 cams would be equally valid upgrades or are the 3.0 better for some reason? Did you use both inlet and exhaust cams? I recall that on the MSD GSi's they only used the 3.0 inlet on the 2.5 unit.
Are there any options from the likes of Schrick or Piper?
What mods do folks to to the air box - there is miles of trunking there and surely it could be larger?
Upgraded sparks / leads any good?
So your list, maped and a decent exhaust will be interesting, especially with the lower gearing of the 2.6 against the larger units.
Post by: i260 on 08 August 2009, 14:38:54
bump!
Also, are the 3.0 and 3.2 cams the same as far as fitting to a 2.6?
Post by: Martin_1962 on 08 August 2009, 21:36:56
3.0 and 3.2 are different but 3.0 are easier to find.
Search for "heads off" and "off with its heads" for threads about Mike and mine cars
Post by: i260 on 08 August 2009, 21:50:46
Any benefits of the 3.2 if they become available?
Am I right in thinking that both inlet and exh need to be done on this engine?
Post by: Martin_1962 on 08 August 2009, 22:51:51
No idea - 3.0 were available so I used them.
Mike got dynoed at around 195bhp
Post by: NiallyV6CDX on 09 August 2009, 16:07:50
Hi
Yes you need to do both the intake and exhaust cams on this engine. Not sure what the difference in cam size/profile is for the 3.2 over the 3.0, but considerind there is only 5bhp between them its probably nothing usefull.
3.0 manifolds and boring out the head ports to match has allready been mentioned.
The throttle bodies can't be bored out as such but the shaft can be filed down and the large obstructive screw heads replaced with grub screws to open up more area when the butterflies are open and improve the flow capacity (I have performed this modification successfully on my throttle bodies)...message me if you would like me to do yours for you :y
I assume "all that trunking" you are talking about is the excess of intake pipe in the box its self? :-?
The standard air box is not really restrictive to the engine, and the MAF sensors can be affected by the oil used in filters such as K&N cones etc..so unless you don't mind having to find a new MAF soon I wouldn't really bother spending any money there as it wont give you significant gains.
The exhaust system....hmmm. As yours is a 2.6 I think (but may be wrong) that it allready comes with the improved pressed steel manifold (as opposed to the cast items on the 2.5s and 3.0s. which are more restrictive). Probably best to check that one, but removing the mid silencers is a useful mod to do, reducing back-pressure (an making it louder too ;)  )
Blanking off the EGR can also give small gains in performace.
Spark plugs and leads won't give you any power gains if the ones you allready have are in good condition.
Remaps I know nothing about...probably best start a separate post about that. :y
Hope that give you some ideas.
Post by: Martin_1962 on 09 August 2009, 18:54:20
Pressed manifolds, no EGR, no plug leads
Post by: GastronomicKleptomaniac on 09 August 2009, 19:11:31
Martin, quick Q - fitting the 3.0 cams into a 2.6, you time it up as normal, right? :y
Post by: Marks DTM Calib on 09 August 2009, 20:32:09
Yes
Post by: Marks DTM Calib on 09 August 2009, 20:34:09
Here is the post I originaly created when doing Mick Dundees 2.6
http://www.omegaowners.com/forum/YaBB.pl?num=1236287115/0
Post by: i260 on 09 August 2009, 22:16:16
Hi
Cheers!
So, basically change the cams and sort out the spindles on the TBs. I have just changed the exh so not going to take out the centres (well, this year anyway!).
The pressed manifolds you refer to - is that the inlet or exhaust?
If I ever need to have the heads off then maybe I would consider getting them matched to the manifolds but not unless.
I have a contact who will sort me out with a map.
Again - thanks.
Post by: NiallyV6CDX on 10 August 2009, 00:25:38
Pressed steel exhaust manifolds, although im pretty sure the 2.6 has them as standard. :y
Post by: i260 on 10 August 2009, 14:14:24
Ok, so is there a mod to do on the inlet manifolds then? Is that a DIY job (any 'how-to's?) or are there any companies that offer the conversion?
Post by: NiallyV6CDX on 13 August 2009, 17:12:03
No just straight swap with 3.0 items.
Post by: i260 on 16 August 2009, 13:34:23
ok -thanks, so when the cambelt change next comes up for change all I need are the 4 cams and the cover seals  to   give to my tame mechanic. Nothing else to bother with.
