Omega Help Area => Omega General Help => Topic started by: sparkyw666. on 18 August 2009, 22:34:06
Title: help tining belt
Post by: sparkyw666. on 18 August 2009, 22:34:06
hi fokes got my timing belt and locking kit and the dvd. must be doing something rong got it lined up on the crank and up round cams 1&2 and the lines on the belt are about 4-5 teeth past the timing marks so gets it all on to see where am i going rong and once it was all on there was far to much play in belt next to the bottom roller it is a gates belt kit and tas yelloy marks to  :y :y
Title: Re: help tining belt
Post by: sparkyw666. on 19 August 2009, 00:00:31
come on guys 21 views and no replys :y
Post by: Darth Loo-knee on 19 August 2009, 00:17:24
I always go anti clockwise ;)
Post by: JamesV6CDX on 19 August 2009, 00:19:46
I'm going to have to try this method, out of interest - I personally go the other way, but am sure to leave the required slack between crank and tensioner...
If you go a/clockwise, which side do you use the wedge?  :y
Post by: sparkyw666. on 19 August 2009, 00:34:26
so not like in the dvd from there are you saying from the bottom to banks 4and3 the 2and1 :y
Post by: Andy B on 19 August 2009, 00:47:40
I wouldn't trust James to put all the cam followers back either!  ::)  ::)  ::)  ::) ;D ;D
Post by: Darth Loo-knee on 19 August 2009, 00:49:33
If you start by putting the wedge in on the left (as your standing at the front) go over the idler (making sure the arrow is at 3 o'clock) first then to Cam 4 pulling the belt as tight as you can get it, then when you get to the tensioner if you have done it properly the belt should just go over the tensioner. :y
Post by: Darth Loo-knee on 19 August 2009, 00:50:37
The wedge on the left James... I have the Trade Mark for Anti Clockwise mate ;D
Post by: sparkyw666. on 19 August 2009, 00:58:12
nice one mate will give it a go in the morning hears hoping :y
Post by: JamesV6CDX on 19 August 2009, 18:35:04
I have two words for you Mr B - the second one is "Off"  ;D  :y
Post by: Andy B on 19 August 2009, 18:44:19
Err? I didn't think you knew any bad words!  ;D  ;D  ;D
Post by: ScottieMV6 on 19 August 2009, 18:44:33
Funny Andy and I were only talking about that yesterday while removing my cylinder heads ;D ;D ;D ;D
Post by: Andy B on 19 August 2009, 18:46:02
 ::)  ::)  ::) Loud mouth!  :-?  ;D  ;D  ;D  ;D
Post by: ScottieMV6 on 19 August 2009, 18:48:19
Ah I didn't say which Andy! [/quick recovery mode]  :y
Post by: Andy B on 19 August 2009, 18:52:47
 ;D ;D ;D ;D :y
Post by: Darth Loo-knee on 19 August 2009, 19:20:08
Obviously now then that even Vicars swear :D
Post by: sparkyw666. on 20 August 2009, 20:05:33
cheers mate worked a treat many thanks :y
