Omega Help Area => Omega General Help => Topic started by: mark.adams on 22 August 2009, 18:11:24
Flat battery one morning this week, managed to get car started by jumping it, ran it for half an hour to put some charge in the battery, switched it off, then wouldn't start again. Charged battery overnight on battery charger, started fine next morning, later that day, alternator light came on on dash and has stayed on since....
Yup alternator has seen better days matey ::)
Any breakers on here got one available???
Just change the bushes and regulator mate...most likely one of these is whats failed...cheap and easy to do :y
Okay, i'll have a go at that, any ideas where i can get the regulator and bushes from???
I'm not far from you and I have a spare. PM me for details and contact number.
BTW, I'd test the battery regardless. When its on the car and its running, put a voltmeter over the battery terminals. it should read around 14.5v.
Battery tested with car running and not, 12.6 volts in both cases, guess that means the alternator is fubarred... >:(
It's either brushes or regulator/rectifier open circuit.
Does anyone know where i can get brushes and a regulator to get this alternator working again please??
