Omega Help Area => Omega General Help => Topic started by: mark.adams on 28 August 2009, 13:06:06
Title: M.O.T Failed
Post by: mark.adams on 28 August 2009, 13:06:06
Failed on emissions... On LPG of all things...
CO was 7.222
LPG ppm vol was 1482
against a max of 3.5 and 1200 respectively.
How on earth can that have happened?
Only thing is battery has been off while i changed the alternator, would that have affected the LPG ECU??
Title: Re: M.O.T Failed
Post by: Jimbob on 28 August 2009, 13:07:24
thats bad luck, should have asked em to try on petrol instead  ;D
Post by: mark.adams on 28 August 2009, 13:13:27
I did, emissions light came on and it failed on petrol too, lambda output out of range
Post by: Jimbob on 28 August 2009, 13:27:10
ahhhh, that gives a bit more to go on then...
maybe a good italian tune up and a bottle of cataclean?
can you check your car for fault codes?
Post by: mark.adams on 28 August 2009, 14:39:22
(http://i273.photobucket.com/albums/jj213/markadams1963/errors.jpg)
There ya go....
Post by: Welung666 on 28 August 2009, 14:40:32
That rather' P0170 again  >:(
Post by: Jimbob on 28 August 2009, 14:41:10
right, at least we have a definate problem to fix now...
(save codes to file is an easier option than screen dumps ;) )
Post by: mark.adams on 28 August 2009, 15:13:54
Is that the first lambda sensor (the one just off the downpipe) and is there anything i can do with it, maybe clean it....?
If i have to replace it, does it have to be a GM one or are the aftermarket ones compatible?
Thanks in advance as always o learned ones  ;)
P.S. just fitted a new exhaust (cat back) that i got from smegmatt1 so its not blowing anymore
