Omega Help Area => Omega General Help => Topic started by: Wolfman on 28 August 2009, 12:31:12
Hi All
Newbie here, does anybody in the Nottingham area own a 1999 2.5 TD so I can view where the vacuum pipes around the egr valve go, has I'm having trouble with the vacuum side of things.
Photos might help.
Thanks in advance
Cheers
Hodgy
Hello and a warm welcome to you Hodgy! :y
I know you have mentioned the Nottingham area, but it would be advisable to fully complete your profile on your exact district / location and your Omega's year. ;) ;)
It will help others to help you 8-) 8-)
where are you?- anywhere near york
Hi Both
I've updated my profile hopefully. I live in Hucknall which is in Nottinghamshire
Hodgy
Can't think of any tractor owners in Nottingham, but the vac goes from main vac line, to solenoid mounted by pas reservoir, then from there to the egr valve.
If yours is one of the less common ones with 2 pipes on EGR, the outside one just vents out somewhere convenient.
mine seems to be the less common ones with 2 pipes on EGR,
The outside one just vents out somewhere convenient
Do you mean the one on the outside of the egr?
