Omega Help Area => Omega General Help => Topic started by: AlexMitton.co.uk on 27 August 2009, 05:53:20
Title: Transmission Bung missing?
Post by: AlexMitton.co.uk on 27 August 2009, 05:53:20
Morning OOF,
My Omega is leaking Automatic Transmission Fluid due to a Bung/Seal which has gone missing?
Does anybody know the proper name for it? Because I cant find it anywhere?
Note to Mod: Note sure to where to post this.
Thanks alot,
Alex
Title: Re: Transmission Bung missing?
Post by: unlucky alf on 27 August 2009, 11:53:20
the best thing to do is first check the filler hole has got its plug in [on edge of large sump drivers side], if thats in situ then id give the g/box a good clean, top it up [follow "how to guide"] then take it for a run & see where the leak is coming from. :y
Post by: dbug on 27 August 2009, 12:25:26
If the rubber bung you mean is the one underneath on the bell housing, then atf leakage from here likely caused by g/box front seal knackered - a gearbox out job :(
Post by: AlexMitton.co.uk on 28 August 2009, 22:38:52
I've had it up on the lift in my mates garage.
I can see a whole where something goes, and oil inside it.
Post by: Andy H on 28 August 2009, 22:47:26
A photo would help to identify this mysterious bung (or a clearer description)
Post by: Andy B on 28 August 2009, 22:48:55
I'm with dbug on this one.  ;)
Post by: AlexMitton.co.uk on 28 August 2009, 22:56:03
OK, I'll get it back on the lift and take a photo.
Cheers
Post by: dbug on 29 August 2009, 16:47:26
Thanx mate - been there, done it!!  Put new seal on, still leaked now swapped box and ok!!
