Omega Help Area => Omega General Help => Topic started by: Bumbazor on 02 September 2009, 13:02:46
Title: Vacuum chamber on top of plenum leaking
Post by: Bumbazor on 02 September 2009, 13:02:46
I lost one of the two o rings that seals between the front of the black vacuum chamber and the throttle body. I replaced it with an o ring I found elsewhere but it's slightly too large and doesn't seal well. It hisses quite obviously when running and I'm wondering if this would cause inadequate operation of my hbv.
Thanks
Title: Re: Vacuum chamber on top of plenum leaking
Post by: Ghost on 02 September 2009, 13:08:22
I would say it would cause inadequate operation of the engine running, and a higher mpg,
they dont cost more than a couple of £££  better getting new ones, if you leave it you will get all sorts of probs.
Post by: Matchless on 02 September 2009, 13:22:51
The O rings are on the breathers so would not affect vacuum (but would affect fuelling as un-metered air is getting in)
The special seal under the black breather assy would affect vacuum and can split if the breather has been removed.
Also check out the vacuum reservoir above the pollen filter, there should be vacuum on its output for several minutes after engine-off. If not look for a vac pipe that has worn through, split rubber connectors ar a failed non-return valve on the vac reservoir
Post by: dbug on 02 September 2009, 21:30:39
£££ - they're pence mate :o ;)
