		Omega Help Area => Omega General Help => Topic started by: capoMV6 on 03 September 2009, 09:20:37
				Is it ok to use other brand of belt (OEM) aside from original VX.  The original cost too much here in the Philippines. An alternative is to use other  brands which are cheaper like Gates for example. Does this hold true for the bearings and waterpump?  Appreciate your advise. Thanks.
				gates or contitech are fine, ive found gates are good. :y
				Always had Gates fitted to my Fiats - never any complaints, good belts :y
				Both Gates and Contitech supply the kits to GM....so no issues with either of them
				Have used Contitech kits on both ours - good quality - got them from HERE (http://www.buypartsby.co.uk/timing-belts-and-kits-final.php?year=1998&Submit=Next&make=Vauxhall&model=Omega&sub=&eng=3.0000)
