Omega Help Area => Omega General Help => Topic started by: Snips on 05 September 2009, 11:29:02
hey all!
i think my miggy has come to its end :( since monday its been constantly over heating and dropping all its water. done all the usall checks, thermostat seems good, fans kick in at about 97, all pipes getting hot.
it just seems to constantaly getting air lock. ive been running up to temp with the cap off and priming the radiator pipes to get the last bits of air out but as soon as i do the cap back up it fills straight back up with air. drive about a mile all seems fine untill i stop. the guage shoots up to 100 so i pull over relive the pressure then the temp will drop to 95 - 97.
theres a huge amout of mayo on the oil filler cap and pipe and somtimes get bule/white smoke out the exhaust :-/
whats your thoughts, expencive garage bill or try somthing else
what area you now? cambrige?
did you check HBV?
you can come over my place can have look for you :y
did you check HBV?
sadly im not, im in stoke at the moment.
thanks for the offer tho!
try contact Loo Knee, after wekend hi will help for you :y
