Omega Help Area => Omega General Help => Topic started by: Anthony on 08 September 2009, 15:28:34
Hi,
i have tried to clean my breathers as the guide said but i cannot get the throttle bodies off the plenum.
Is it possible to clean it in situ, with the engine running? or has it got to be taken apart?
sorry forgot too mention i am only cleaning the plastic bit on top.
Many thanks
Anthony
Have you taken the top cover off and taken out the torx bolt?
you can use an 8mm nut to get the 4 torx bolts off the front of the pleunum, if you cant get to them loosen the pleunum and lift it, they are not very tight.
Thanks for the reply, i have done the torx bolt on the top, will try the plenum.
Anthony
