		Omega Help Area => Omega General Help => Topic started by: rossi123 on 15 September 2009, 20:59:23
				does anyone know were the bolts are for the bumper need to get it off anyhelp would be appreciated
thanks paul :)
thanks paul :)
Front or rear?
				sorry i'm a prat haha the front  :)
				Easy.....
4 x torx screws, 1 each side inside front wheel arch, 1 each side under the bottom of the bumper nearest fron tyre.
3 x plastic push tabs underneath. Pull out the centres then pop out the plastic lugs
And finally 2 sinilar push tabs on the top of the bumper.
As you pull it forward you'll see the 1 elec connector that needs to come off.
Only other thing is the headlight washers (if fitted), they are just push on pipes
HTH :y
Lee.
				thanks very much your a star  :)
