Omega Help Area => Omega General Help => Topic started by: SMD on 16 September 2009, 21:12:33
whats the correcy tyre pressure for the 15" wheels (i think)? mine is the 2.5V6 so not sure if its 15 or 16"
cheers
You should look in the manual, page 227, see here:-
http://images.omegaowners.com/documents/UserGuides/OmegaOct2002.pdf
Yours are about 30psi, I tend to run at 31 all round, but if you are carrying heavy loads, you may need to put more in, especially the rears.
The size will be marked on the tyres, you probably have 16s, but a 15" spare.
thanks ;)
is it not 31.5 psi?
is it not 31.5 psi?
Thats what i run mine at (well 32)
I have tried higher pressures but compromise the ride.
I run 32psi all round on the saloon & 32psi front and 34psi rear on Estate (both 16" wheels)
HTH :y
