		Omega Help Area => Omega General Help => Topic started by: Richie London on 19 September 2009, 22:31:47
				ihave to take mine off tomorrow, either to replace or just grease. do i need to take the cable tray off first. any tips or advice will come in useful.
				I may be wrong but i'm sure when I did mine that I just took it off without removing any other parts, other that the belt of course  :y
 Cheers,
 Richard
				As RichB says, just the belt to remove :y
				cheers
				 ...... any tips or advice will come in useful.
 15 mm socket/spanner, anti clockwise.  ;)  ;)  ::)
 thank god someone knows what there doing, i would have probably gone clockwise  ;D ;D ;D
 mines held on with 2 of them silly reverse torx bolts.  :-/ :-/
 I was talking about the actual roller so you can remove the 'fan belt', the tensioner itself uses Torx head bolts.  :y
 The seconday air pipe passes through the aux belt, so that has to be undone to get the belt off.  :y
 oh yeah. sorry :-[ :-[  ;D
				The seconday air pipe passes through the aux belt, so that has to be undone to get the belt off.  :y But... if you are keeping the old belt you can leave it hanging over secondary air pipe while you work on the idler.
 Agreed!  :y
				Well worth checking and doing as  I found out at Newent when mine seized up in the middle of the camp site  >:(
 But OFF to the rescue   :y
