Omega Help Area => Omega General Help => Topic started by: mick-1975 on 28 September 2009, 22:03:13
hi brought a car the othere day ,and it drives spot on ,i noticed that the gearbox was slipping when warm ,checked the level all is good ,
now if i pull away sharp the whole rear of the car seems to check and judder ,
been underneath today to check the diff level ,
and the bushes on the back and all is good ,
this is really puzzled me ,im thinking its the gearbox slipping , but would it cause it to do that ,???
if i pull away smoothly its fine !!
could do with someone local on here to have a listen to it , and see what they think
look forward to the replies ,
if i need a box ill get it from on here from marky mark :y
does the eml come on now and again,,does it jerk when changing gear ? does it seem to have a flat spot on accelaration.sounds like it takes ages to change up a gear...i had this problem and it was the camshaft sensor on my 2.2.. :y
thks ..no eml light on at all ,
changes gear spot on when cold ,smoothly and pick up very well ,
just that u cant pull away sharp as it judders ,vibrates , ...got me puzzled as i have checked everything ,
i have noticed that when warm it does not select 1st all the time and slips ..
also if u put it in drive ,there is quite some time before it selects the 1st gear , !! :y
