Omega Help Area => Omega General Help => Topic started by: barclay03 on 05 October 2009, 13:27:43
Having a few problems with the mig over the past day or 2.
1. The handbrake light keeps dimly flashing/staying on when im driving but the handbrake handle is fully down. Im going to check the switch but asking incase its a common thing that i dont know about :y
2. My heaters dont seem very warm. They used to burn my eyeballs out when it was set to HI, now its just luke warm air thats comming through :-/ the coolant was recently changed, engine temp sits fine at 95ish... any thoughts on what could be wrong?
thanks in advance!
Heaters,
you could try a servo rest - auto and off for 5 seconds.
did you get all the air out the system when you did a coolant change?
you could flush, and reverse flush the heater matrix...
pull the pipes off where they go into bulkhead, push on hose and run for 5 mins, both connectors. I put another bit of hose on the other to drain under the car.
Top your brake fluid up
thanks for the suggestions guys :y
Will try the servo reset first before redoing the coolant.
Brake fluid was low, think it might be leaking some - advisory on MOT was corroded rear brake lines, so ill have to get under it and check just how bad they are then probably replace them. I knew the light flickering would be something like that lol
Cheers again :y
you only lose a little coolant, your are only doing the matrix :y
Cool - will maybe give it a go this week if the reset doesnt do anything :y
whats the easiest way to get into those pipes to flush when the winter pack doodah is fitted?
also, is there any bleeding points in the system that i dont know about?
cheers
As Jimbob says ^^^^^ did you make sure there are no airlocks in the system :question
Engine idling, heater controls set to max, blowers on max, expansion cap off and "burp" the top hose :y
Will give that a try :y
first coolant change on an omega so unsure of the right protocol ;D im used to bleeding screws within the system (from working on french crap)
how to disconnect the heater matrix pipes :
http://www.omegaowners.com/forum/YaBB.pl?num=1185891036
how to flush all coolant :
http://www.omegaowners.com/forum/YaBB.pl?num=1167917774
