Omega Help Area => Omega General Help => Topic started by: 3.2 manual on 13 October 2009, 18:12:55
right oh, problems started. not sure its due to k&n but ill do my best to exlain as one reading has been like this since ive had the car. in the morning starts instantly, after work turn the key, it starts(but has stalled again, like the old vauxs did when starting from hot) but runs rough as a badgers ass at about 300 rpm. blip it picks up fine then ticks nornally. intake temp has always been high eg air temp=16c, intake temp=39c. but now code 110 has made itself known. is it tech 2 able or is it in the flowmeter. it odd because the intake temp varies but hasnt changed from the old vaux filter. 420, 430 are back, but thats ok cause i missed having them! maf on tick over 2.5-3.00G/S? is it right?
beleive intake temp. only used when cold starting so they tell me. Mine plays up when its really warm weather, so not a problem really......
0110 intake temp. circuit. Voltage high. Or voltage low. If that helps it all. :-(
Is this a cone filter and how is it installed?
no panel filter, was worried about oil contaminating but took off pipe from box to meter, dry as a bone, nout not even a hint. the starting bit is odd thou crank sensor? well mine had been sat in the sun all day so maybe 110 not such a problem?
Might help. ?
http://www.omegaowners.com/forum/YaBB.pl?num=1255204857
cheers, thats me chris, but another code now
