Omega Help Area => Omega General Help => Topic started by: acura on 15 October 2009, 06:08:49
Hi, just (yesterday) took delivery of my 02 2.2 auto Omega. It is off the road at present as I'm gonna do a full sevice and renew the timing belt/rollers/water pump etc.
There doesn't seem to be a Haines manual for this engine but one for the earlier 2.0
2 questions: will the 2.0 information in the Haines book do for the 2.2? and better still is there a 'how to' do this job on this forum? Forgive me if I've missed it.
I'm a competent home mechanic but need to know if I need any special tools etc before I start.
Thanks for any help.
They are pretty much the same engine so the 2.0 haynes will cover it :y
is the same think its just the bore size dif,you will need to lock the top and bottom and some star sockets and 13m spanner and socket, and a rubber hammer to get the crank wheel off. :y
Think you will find only the top needs a lock ;)
Its a 4 pot, you only lock the top
2.2 is a stroked 2.0, so 2.0 manual covers it.
Need a £5 locking wedge. Change waterpump at same time, and ensure its a full cambelt kit rathr than belt only
additionally, there is a 4 cyl cambelt dvd in the OOF shop. Its not great (the v6 one is excellent), but for sake of £3, might prove useful
I wouldn't bother with the 2.0 DVD, it was late, rushed, and not close up enough.
It was more of a case of just filming me fit one, rather than a how-to....
Actually, I didn't realise the shop was selling it, I think it should be withdrawn
We hope to do another, but whilst there is nothing else better, its better than nothing :y
Yeah I guess ::)
I did a 2.2 a few months ago, I had every good intention of some hi-res pics to make a guide, but entirely forgot... :-[
Thanks for all your info guys.
I'll probs invest in a Haynes manual, even though its for the pre-facelift.
Do any of you recommend Autovaux for you parts? They seem reasonable. Do the parts seem to be good quality? Do you think I may be able to get the lock tool from them?
Any recommendations appreciated as I'm not used to Vauxhalls.
With my current millage mine will need re-doing within 6 months, so could film that one?
I would no longer recommend autovaux - they have a habit of telling you its a genuine part (or a part made by a GM supplier), but its not the same quality as a genuine part.
I have just said the same to someone else :)
Exactly the same here
Although they did supply me some Gen GM rings for the Astra - which were £218 cheaper than the dealer :-/
Actually guys, I bought the 2.2 DVD and found it very helpful. Granted it isn't ideal, but I had never attempted a job like that before and had no problems whatsoever :y
Thanks again for the advice.
Where would you recommend for the timing belt kit and water pump? Also the required locking wedge, is this a Vauxhall part or will a motor factor sell them?
Cheers
Try these people - cheaper than Vx and kits are Contitech (one of the Vx oem suppliers - other is Gates) - I've used 2 of these for V6s and good quality, fast delivery and no probs to date! Click - http://www.buypartsby.co.uk/timing-belts-and-kits-final.php?year=2001&Submit=Next&make=Vauxhall&model=Omega&sub=&eng=2.2000
i had to lock the bottom as it keep'd moving.
Cheers
WAter pump from same place as belt above, cam lock off ebay - you only need to lock top end on a 4 pot
Most factors will sell a draper lock for around a fiver, though they may have to order it in (as its specific to a range of engines)
Cheers. I've ordered a lock from Laser so ok there. I've been onto eurocarparts and they have the Contitech kit and Vx quality water pumps. I guess Bosch oil filters and plugs are ok? I'll get all my stuff from them and give it a full service too.
yes water pump is a must too, its cambelt driven on 4 pot, and its worth replacing it, £45 odd (or what ever it is now) is cheaper than an engine rebuild if it fails. :y
Is the water pump for a 2.2 the same as the 2.0? I ask this because the belt on my 2.2 estate is due for replacement soon and I still have a new pump that was never fitted to my old 2.0 estate (I have been saving it for my wifes 1.8 Vectra but that had the water pump changed just before I bought it).
