Omega Help Area => Omega General Help => Topic started by: rustym95 on 21 October 2009, 03:12:24
Title: eco button
Post by: rustym95 on 21 October 2009, 03:12:24
Have finished doing up engine, runs sweet, had every thing off and clean'd or replaced, was looking on e-bay and there was a eco button same shape as my mid dash, have taken the cover off to see if it was live, as when got the car it had no covers on now has 2, gose heat seat pass, blank, panic button, hazzards, air recl, big blank space, then seat heater driver, were would the button fit, and what dose it do. thanks for your help
Title: Re: eco button
Post by: alexh551 on 21 October 2009, 06:19:58
eco button disengages your aircon pump. the button goes 3rd in from the right (i think)
cheers
alex
Post by: Welung666 on 21 October 2009, 07:27:17
Left to right:-
Pass. Heated Seat - Rear Blind - Alarm Sensors - Heated Rear Screen - Hazards - Re-circ - ECO - TC - Drivers Heated Seat
Post by: I_want_an_Omega on 21 October 2009, 07:33:54
Hi Rusty
If the big blank is a double sized one then it will be covering up the positions for TC (traction control), and Aircon/Econ switches.
That means your car wasn't fitted with Aircon, so the discussion about Econ is somewhat meaningless.
The single blank on the left hand side would be where the rear blind switch for a saloon would go. Thing is you will probbly find wiring behind these swiches depanding on what wiring loom they used when building the car. The saloon and estate looms are in two halves, so thats why the rear sunblind wiring would be there, but when it gets as far as the joining connector for the back, that connection will stop.
HTH ,,,,,,,,, Rob
Post by: Welung666 on 21 October 2009, 07:38:31
Rob my rear blind switch is to the right next to the drivers heated seat switch, I have a blank next to the pass. heated seat which is where the TC button should go (mines a manual so doen't have TC). I'm pretty sure the positions never moved between 95 and 99 models.
Post by: Ratty on 21 October 2009, 07:46:37
I think there must be different configurations depending on model and year. Mine is a 99 cdx estate and the only one i'm missing is the rear window blind button for the saloon.
(http://i4.photobucket.com/albums/y149/ratsalad/Public/th_DSC_2464.jpg) (http://s4.photobucket.com/albums/y149/ratsalad/Public/?action=view&current=DSC_2464.jpg)
Post by: Welung666 on 21 October 2009, 07:50:56
Mines a 99 CDX too. I'll have to move my blind switch then. No blind fitted (yet) just got the button in the hole. It seemed to fit ok though  :-?
I'll edit my original list then :P
Post by: Ratty on 21 October 2009, 07:57:06
Ahh yes, the edit button, best invention since sliced bread ;)  ;D
Post by: I_want_an_Omega on 21 October 2009, 07:57:38
All the Omegas that I have had he switches are as shown in Ratty's picture
Post by: rustym95 on 21 October 2009, 09:33:23
thanks i will leave it then, got button covers as there was no buttons there when got the car. thanks for the help just be getting new back box then :y
Post by: tunnie on 21 October 2009, 09:38:11
On some mini-faceliftts TC/Traction buttons were moved down and were long thin buttons
Post by: Ratty on 21 October 2009, 10:45:54
I could be wrong here but I thought the long thin TC switch were on the earlier Miggys, my old 95 CDX had a long thin TC switch where the coin tray/sat nav is
Post by: I_want_an_Omega on 21 October 2009, 10:53:49
You will find the other end of the wiring for the blind tucked away up in the top left corner of the boot
Post by: I_want_an_Omega on 21 October 2009, 10:57:02
Yes, you are right. My '96 had the TC switch next to the radio. The switches moved with '98 models I think. The early Elites had rear door demisters which were operated by a switch in this bank - but its so long ago now I can't recall exactly where it was.
Post by: tunnie on 21 October 2009, 11:05:52
i remember why now, early Elites had buttons for rear side widow de-mist. These were dropped with 98's and so those buttons moved up and sat nav screen put in
Post by: I_want_an_Omega on 21 October 2009, 11:12:52
Thats right, although the Mini facelifts were launched as a 97.5 MY which is who you see some mins with the TC button in the old place, and '98's onwards in the new one with the cubby hole added
