Omega Help Area => Omega General Help => Topic started by: bushwacker on 03 November 2009, 21:53:57
Title: my 2002 omega 2.2 petrol is in limp mode
Post by: bushwacker on 03 November 2009, 21:53:57
first of all hi to you all ime new to this site ...
ok my omega has the light with the spanner on . and keeps going into limp mode any help please it driveing me up the wall ive got to go 80miles on thursday and ime worried about this
Title: Re: my 2002 omega 2.2 petrol is in limp mode
Post by: tunnie on 03 November 2009, 22:01:27
2 main things cause limp mode, gearbox, or cam sensor.
Most likely its the cam sensor, can you get the codes read?
Update your profile with your location, someone near you may have tech2
Post by: bushwacker on 03 November 2009, 22:06:47
oh ok does the cam sensor cost ££££££££ ..and how do i update my profile sorry to be a pain ...and ime in wolverhampton
Post by: tunnie on 03 November 2009, 22:09:04
User CP > Profile > Edit Profile
Cam sensor is not expensive, think its around £60ish? can't remember.
Easy as pie to replace, go for genuine part, pattern have had a poor history for this.
Get codes read before you go replacing parts though  :y
Post by: mathewst on 03 November 2009, 22:09:07
Cam sensor is around 60 pounds.
you must buy original part, aftermarket ones don't work on 2.2
Post by: bushwacker on 03 November 2009, 22:19:54
is there anyway i can do a quick fix just to the weekend as i need it thursday
Post by: mathewst on 03 November 2009, 22:22:59
car could  work normally from time to time.
But it is 10 minute work to change the cam sensor if that is wrong.
See if anyone can get the codes read first.
How many miles has the car got on clock?
Post by: tunnie on 03 November 2009, 22:24:41
Cam sensor either works or it doesn't, like i say you need to read the codes. Cam sensor is just one possible cause, the gearbox could be giving a code causing same symptoms.
Closest tech2 to you is Brackley (NN13)
Do you have a laptop? Can get a 'cheapo' tech2 off eBay
Post by: bushwacker on 03 November 2009, 22:24:46
car has done 150000 full vauxhall servlice history
Post by: tunnie on 03 November 2009, 22:26:07
Good miles, keep on top of those coolant changes  :)
Post by: mathewst on 03 November 2009, 22:26:48
Well cam sensor usually lasts around 100 000 or a little more so it probably is dead.
Can you check on service history has it been changed anytime in the past?
Post by: bushwacker on 03 November 2009, 22:28:24
ok at least ive got an idea thanks lads
Post by: mathewst on 03 November 2009, 22:29:46
Is the car auto or manual?
Post by: bushwacker on 03 November 2009, 22:30:18
auto
Post by: mathewst on 03 November 2009, 22:31:53
So it also could be the gearbox.
Unfortunately you need the codes read
Post by: bushwacker on 03 November 2009, 22:33:40
ok but when it isent in limp mode the gearbox is fine does that mean anything?
Post by: tunnie on 03 November 2009, 22:35:08
Does it rev over 4k rpm? Assuming not as you said its in limp mode. Can still be the gearbox, its like a safe mode for it.
Post by: bushwacker on 03 November 2009, 22:38:22
yes it can rec  to that quite easy untill it goes into limp mode ...also how would i tell if the cam sensor has been changed in my service book?
Post by: Ken T on 03 November 2009, 23:09:16
One advantage with the 4 pots is that if the cam sensor goes, the car will keep going, only at reduced speed. On the V6's, the engine dies and that's it.
Changing it is fairly easy, if I remember its at the front of the engine just under the belt cover.
To accurately diagnose it you need a Tech 2 or a good code reader (not the Elm 327 ones) there were some cheap chinky ones on fleabay, that were a copy of a moderately expensive one, but we don't talk about them..............
Ken
Post by: davethediver on 04 November 2009, 00:52:07
Any half decent code reader should give you the codes, sounds very similar to what happened with mine, would drive ok then just not rev past a certain amount no matter how much i floored it. Changed sensor and hey presto all fine now.
As said before i think part was about 60 quid. But someone local may pop over and read codes for you, don't start spending money on changing parts till your sure thats what it is :y
Post by: Welung666 on 04 November 2009, 06:08:16
Bushwacker, I'm only in Dudley and can read/clear the codes for you. If it proves to be the crank sensor (as I also believe it is) then I'll talk you through changing it too :y
Post by: bushwacker on 04 November 2009, 13:59:44
welung666 did you get my pm?
Post by: Welung666 on 04 November 2009, 14:10:02
Yes matey :y I'll give you a bell later this afternoon :y
Post by: portomega on 04 November 2009, 14:44:44
i seem to have the same problem with my 2.2 , but only seems to go into limp mode when the engine is started and its hot if i start the car when the engine is cold it will start fine.....is that a sign of the cam sensor going?
Post by: davethediver on 04 November 2009, 14:47:59
Do you get any warning lights on the dash, would advise getting the codes read better safe than sorry :y
Post by: ajn on 04 November 2009, 15:56:10
hello i had this problem with my 2.2 auto turned out to be as tunnie said my selector switch on the side of the gearbox,changed it with one i bought off one of the lads on here no more limp mode or spanner light on dash have you noticed the lights on the side of the gear lever (p 1 2 3 d r) flashing or all on if so could be your problem ajn
Post by: bushwacker on 04 November 2009, 18:09:22
SO IS THE SELECTOR SWITCH ON THE SIDE OF THE GEARBOX THE SAME AS THE CAM SENSOR OR NOT ? ?
Post by: Welung666 on 04 November 2009, 18:21:17
No nothing alike matey, your phone's gonna ring any second ;) :y
Post by: bushwacker on 04 November 2009, 18:40:46
just like to say a big thanks to all the advice ive recived already
and welhung666 thanks for the call i hope i can sort this out soon ! ! :'(
Post by: bushwacker on 04 November 2009, 19:00:23
just a note to the lads who asked if the gearbox lights are flashing or sticking on ....so i just took it out.. no flashing lights on the gearbox or lights sticking on the gearbox just the one with the spanner through??
Post by: Welung666 on 04 November 2009, 20:32:51
Who? ;D ;D ;D ;D
Post by: PhilRich on 04 November 2009, 23:29:30
Who? ;D ;D ;D ;D
How did he find out Lee?, he can't be psychic or he wouldn't need a code reader ;D ;D ;D ;D ;D ;D ;) :y
Post by: davethediver on 05 November 2009, 00:43:07
Who? ;D ;D ;D ;D
 ;D ;D ;D ;D ;D :y
Post by: mathewst on 05 November 2009, 08:44:04
Hmm after this :y I think Welungs' popularity among female forum members is definitely going to go up:-)
