Omega Help Area => Omega General Help => Topic started by: tunnie on 04 November 2009, 22:37:43
Title: V6 Stat
Post by: tunnie on 04 November 2009, 22:37:43
Do you need to replace the stat housing bolts, when replacing the stat?
I understand there was a change to the V6 stat housing at some point, resulting in longer bolts.  :-/
Title: Re: V6 Stat
Post by: Matchless on 04 November 2009, 23:02:42
Later stat housing has a thicker flange so longer bolts are needed.
Title: Re: V6 Stat
Post by: Weds on 04 November 2009, 23:04:20
My replacement was thinner, shorter bolts needed..
Title: Re: V6 Stat
Post by: Matchless on 05 November 2009, 12:45:02
So you were given the old style one. Old stock?
Title: Re: V6 Stat
Post by: tunnie on 05 November 2009, 13:22:05
Did the stat come with bolts / flange? Can i just replace the stat and use the current bolts?
