Omega Help Area => Omega General Help => Topic started by: Canon Cam on 23 November 2009, 23:01:51
Title: Auto Box stuck in Park
Post by: Canon Cam on 23 November 2009, 23:01:51
Hi Guys,
Tonight the missus called me because she could not get the gear selector out of "P".
Drove down there and knew from previous issue, that I could remove the selector surround and move the little yellow plastic forward and job done...could select gears again.
Now, back at home, car in P and same thing...cannot  move the selector.
Is there an easy proper fix rather than having to keep the cover off and move a little plastic tab every time we want to move after parking?
cheers
Mark
Title: Re: Auto Box stuck in Park
Post by: hotel21 on 23 November 2009, 23:03:48
Check wiring/replace the solenoid?   :-/  If there is one - guess there is....
Post by: Andy B on 23 November 2009, 23:05:21
Hi Guys,
cheers
Mark
Failed/failing brake light switch ....... :y
before you say that your brake lights work, so it can't be the switch  ;) there's 2 sets of contacts in there.
A new switch sorted the same problem on mine, about £20 IIRC  :y
Post by: RobG on 23 November 2009, 23:06:13
Very seldom the solenoid. Dodgy brake switch up behind brake pedal :y
Sh*t must type faster :D
Post by: Entwood on 23 November 2009, 23:06:49
Its either the solenoid or the switch on the brake pedal AFAIK ... best get a circuit tester on it and try and see which.  I believe the brake switch is the more common failure ..
HTH
(ps .. don't think there's a seperate fuse but check fuses number 9 & 26 .. they are mentioned as auto transmission in the hand book )
Post by: Canon Cam on 23 November 2009, 23:40:33
thanks for the quick replies guys.
Will investigate further in the morning.  Worst case scanario will just have to keep moving the plastic flange each time until gets new brake switch fitted.
Post by: RobG on 23 November 2009, 23:46:23
Or remove the assembly `till you get the new switch :y
Post by: Canon Cam on 23 November 2009, 23:49:39
yep, was just thinking of taping it in the open position for now.
Post by: sneakypenguin on 24 November 2009, 00:28:46
Is there a guide anywhere on how to do this? Mine needs doing and don't wanna guess on how to do it, cheers
