Omega Help Area => Omega General Help => Topic started by: hewis on 24 November 2009, 13:13:52
I have just bought omega 2.5v6 on a 99 and it idles at 450rpm how do you turn up the idle speed
You can`t. Anything between 450 and 600 is considered normal.
Mine always idled (smoothly) at 550.
If it is rough or struggling then in might be a symptom of a sticking ICV (idle control valve) or a host of other minor ailments.
Start by cleaning the idle control valve and checking for fault codes. Cleaning the crankcase breathers would be a good move also.
Don't think so Rob, idle engine speed should be higher than than, around 700-750 RPM.
400 is too low.
It looks like idle control valve isn't working properly
450 idle is not unusual for a V6 with aircon off. Switch on the a/c and it will lift to around 500/550. Its non adjustable as said, but cleaning the idle control valve, if fitted, will ensure its running at its best.
400 is too low.
Too high for a V6
Mine idles smoothly at 500
Yup, 500 with the AC on.
Geoff
450-500rpm - Aircon off
650-700rpm - Aircon on
Not adjustable and note, the rev counter accuracy varies!
