Omega Help Area => Omega General Help => Topic started by: bigdods on 13 November 2009, 21:58:07
Title: Need to disconnect the SAI
Post by: bigdods on 13 November 2009, 21:58:07
Well its been noisy for a while but now the SAI has failed. So instead of grinding for 30 secs it now is mostly silent but the dash lights go dim then bright every second for the 30 seconds when its supposed to run. Amazed that no fuse has blown !
Now as I understand it I need to remove the n/s front wheel, remove the wheelarch liner and then behind it I should find the SAI which I then simply unplug, is that right ? Is it obvious once the liner is removed ?
Cheers
Dodsy
Title: Re: Need to disconnect the SAI
Post by: TheBoy on 13 November 2009, 21:59:49
Can do without removing liner - you can feel for the connector :)
Post by: TheBoy on 13 November 2009, 22:00:24
Or take it to Oak Road, and send a Tunnie in to the narrow bits ;)
Post by: bigdods on 13 November 2009, 22:02:57
aha well if its a size thing I have the answer right here. I'll send my 9 year old in to do the job....
Glad I dont have to remove the liner, I'll stick an arm up there on sunday and see what I can find
Post by: KillerWatt on 14 November 2009, 09:00:43
Or just pull the 50A fuse that supplies it with power.
Post by: bigdods on 14 November 2009, 10:16:24
now this seems a much more sensible idea, 50A holy crap no wonder my lights are dimming when it tries to run !
Post by: bigdods on 16 November 2009, 16:41:47
Having looked in the user guide the 50A fuse dfor the SAI isnt shown, so I guess its one of the fuses under the bonnet that are shown as 'dealer only' items in my handbook  ;D
I havent had a chance to get under there yet, will it be obvious which fuse I need to pull - is there just the one 50A fuse ?
Cheers
Post by: JasonH on 16 November 2009, 20:46:14
The fuse is in the under the bonnet fuse box next to the battery. It's big and orange and I think it's the only one like it in that fuse box.
Post by: Entwood on 16 November 2009, 20:48:35
Do these piccies help at all ?
http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
3.0 litre is the second one but I don't see the SAI listed ??
Post by: Ian_D on 17 November 2009, 00:22:39
The SAI pump surly cant be 50A can it?  :-? :-? :-? :o :o
Post by: rustym95 on 17 November 2009, 00:50:20
i bet it is full of water in the motor fan, could mean that the valve is letting exhaust gas in and is going the wrong way. main fault is water. pull pipe off if it comes out then valve is gone.
Post by: Abiton on 17 November 2009, 07:53:15
Why not? At 14V that's only 700W; your toaster is more powerful.  ;D
Post by: Ian_D on 17 November 2009, 22:46:28
It just sounds like a lot  ;D ;D ;D
Post by: bigdods on 23 November 2009, 22:11:12
50A fuse removed... silence is golden ! Cheers for the advice  :y
Post by: TheBoy on 24 November 2009, 19:07:09
A photo of which one would make a great guide ;)
Post by: KillerWatt on 24 November 2009, 20:29:34
IIRC, there is only one 50A fuse (in the fusebox next to the battery).
Post by: KillerWatt on 25 November 2009, 08:17:52
No it isn't, but the initial start up current is pretty damn close.
Post by: Andy H on 25 November 2009, 10:58:33
To avoid over stressing cables and fuses you should try and select a fuse & cable rated at twice the current you expect.
A 50A fuse is intended to blow at 50A. If you run at the limit things start to get warm and the voltage drop can cause problems.
Post by: bigdods on 25 November 2009, 20:59:28
Correct, there was only one 50A fuse. I will take a piccy of the fusebox at the weekend and post up for use as a reference - is this something worth adding to the Technical guides ?
Post by: KillerWatt on 25 November 2009, 21:02:44
;D ;D
Post by: Marks DTM Calib on 25 November 2009, 21:46:30
Nah....I2t mate!
Post by: Marks DTM Calib on 25 November 2009, 21:48:04
Best explanation I can find is here:
http://www.circuitprotection.ca/fuseology.html
Post by: Andy H on 25 November 2009, 22:58:20
The SAI pump surly cant be 50A can it?  Huh Huh Huh Shocked Shocked
The point I was going to make (but failed  ::)) was that a 50A fuse is probably protecting a circuit that normally draws around 25A.
Post by: Marks DTM Calib on 26 November 2009, 08:36:09
Again, it depends on the fuse type.
The circuit (with the correct fuse type) could be 40A with an in-rush current of 150A for a short period.
Also remember, a fuse does not protect the circuit, it protects the supply (as if it blows, there is already a fault in the circuit)
