Omega Help Area => Omega General Help => Topic started by: Brick Tamland on 29 November 2009, 14:18:22
Title: Crank sensor on its way out?
Post by: Brick Tamland on 29 November 2009, 14:18:22
Got a phone call from the old man last night, he said his 2.5 was revving on its own up as far as 5000rpm but went away after a while. Havent had a chance to look at it myself (not in this wheather anyway). Is it early signs of a crank sensor?
Its a 1998 gls and there's 97k on the clock and AFAIK it still has its original sensor so that must be a record ::)
Title: Re: Crank sensor on its way out?
Post by: Andy H on 29 November 2009, 14:28:19
Petrol or diseasal?
The classic cause of diesels 'running away' is oil carry over from a blown turbo seal. :o :o
Post by: Brick Tamland on 29 November 2009, 14:32:15
Petrol or diseasal?
Nope, it doesn't have a moustache and its not called Brian ::)
Post by: Andy H on 29 November 2009, 14:46:01
AFAIK the crank sensor only ever causes a lack of go not too much.................
I would start by cleaning the idle control valve and breathers.
Post by: Brick Tamland on 29 November 2009, 14:51:33
Will do :y If it clears up that is :-/
Post by: tunnie on 29 November 2009, 14:52:34
No, Crank sensor failing symptons are the engine dieing, not restarting. then 10 mins later start ok.
I would be checking / cleaning the throttle body / butterflys
