Omega Help Area => Omega General Help => Topic started by: RobG on 28 November 2009, 23:23:07
Anyone know the normal running temp on a facelift 2.0. Mine sits between 75 and 80. Is that about right :-/
My 2.2 normally runs about 85 according to the guage .... basically the same engine
HTH :y
Seems a bit low, as said above, my 2.2 runs at a constant 85.
too low, sounds like a sticking stat, mine did the same. Replaced it, and it always runs bang on 85 now :y
Would that contribute to my heater problems?
Possible, try replacing the stat. Its nice and easy on 4 pots
Theoretically, if the stat is malfunctioning, could it cause coolant loss through evaporation due to boil off :question
Yours is running sub 80 most of the time, so no, it can't do that cause it can't boil :)
No.....and even if it was only getting to 70 degC then you will still get hot air.
