Omega Help Area => Omega General Help => Topic started by: largespeakers on 29 November 2009, 14:34:31
Hi, my 2.5 v6 cd 1999 manual estate has suddenly developed heavy steering. Fluid level is fine. Help please.
Is your ABS light on?
(ABS ecu also controls traction control, speedometer and speed sensitive steering)
Check the cigarette lighter. If its not working then check fuse 14 in the cabin fusebox. This also covers the electrical assist on the power steering.
see:- http://www.omegaowners.com/forum/YaBB.pl?num=1161602010
Normal cause is a small coin - penny or 5 p piece - falling in and shorting it out.....
could be a tired pump, does it happen mostly at low revs? What happens if you rev high, does the steering become light again?
thanks for all your quick answers. There is no light on, it happens at all revs and I will check the lighter.
It was the fuse, childs foot had jammed rear lighter in, many thanks to forum members who helped me
splendid..... :y
