Omega Help Area => Omega General Help => Topic started by: goonv6 on 10 December 2009, 11:59:17
Mine a leaking like a good un and its causing problems with the abs/ traction control as the sensors are getting covered. Anyone replaced these? The book of lies says that you need to preload the front one but I have no idea how to do this. Any thoughts?
We have a guide...
index link in my sig, or
http://www.omegaowners.com/forum/YaBB.pl?num=1157722402
The sensors are sealed so a bit of oil should not affect them....likely to be a different problem.
Replacement of pinion seal is in the guide.
Drive shaft seals are easier:
Unbolt and remove abs sensor (for protection)
Unbolt driveshaft from hub
Lever driveshaft out of diff with prybar / large screwdriver.
Clean up the mess then lever out old seal and press in the new one (either tap it in a bit at a time, working round the outside with a soft drift or find a suitable tube to drift it in)
Refit driveshaft etc and top-up the diff.
Hi,
I followed guide on here for front seal change and had no problems. Make sure you have a 30mm DEEP socket. You can't do without. Get oil to top up afterwards, I think mine lost 600ml in front seal change.
I don't know if it is just an estate version thing, but I found the exhaust pipes were in the way a lot. I postponed this job untill I also fitted a new exhaust. Made it much easier with pipes out of the way.
Roger
