Omega Help Area => Omega General Help => Topic started by: steve2.5cd on 22 December 2009, 17:20:09
Title: Outside temp sensor
Post by: steve2.5cd on 22 December 2009, 17:20:09
Hi guys. need your advise. i have changed the temp sensor twice one brand new and one off a scrapper and still cant get a proper reading. the used one is reading nothing and the new one read -32 then -64 then went off. any advice would be good !
Title: Re: Outside temp sensor
Post by: sneakypenguin on 22 December 2009, 17:32:55
it could be a wiring problem, have a look at the wires incase the protective plastic casing has worn off and exposing the wire, or could be a duff sensor.
Post by: steve2.5cd on 22 December 2009, 17:49:22
thanks for that. i will check the wiring if it ever stops snowing ! lol   ;)
Post by: sneakypenguin on 22 December 2009, 17:51:51
lol, not something you get to say often 'if it ever stops snowing'
Post by: RichardH on 22 December 2009, 19:36:07
Follow the wire from the sensor back until you come across an electrical connector. (On the facelift it's under bumper in front of passenger side wheel).
Water can sometime get in here and corrode the pins.  If so, just snip the wire and join them directly.
Post by: steve2.5cd on 22 December 2009, 22:39:39
Thanks, I will try ang look tomorrow
