Omega Help Area => Omega General Help => Topic started by: robclowes on 07 January 2010, 08:51:02
Title: Pass door wont unlock
Post by: robclowes on 07 January 2010, 08:51:02
Hi
My passenger door has a problem where it dosent unlock/lock off remote but WAS fine mnually. Now it wont unlock at all!!! Is it due to the weather?
Any ideas?
Title: Re: Pass door wont unlock
Post by: rustym95 on 07 January 2010, 09:29:53
would check the wire plug from A post to the door may have a bad connection, dose you speaker in the door work?
Post by: VXL V6 on 07 January 2010, 09:41:39
When you say 'manually' do you mean pulling the lock up and down on the inside or with the key in the drivers door?
Most likely to be a lazy lock solonoid as covered in the maintenance guides on here.
Post by: jack68 on 07 January 2010, 09:48:47
It is most likely to be the bad weather.  I have had the same problem at this time of the yaer for the last couple of years.  It will sort itself out when it gets warmer.  If it doesn't then look at repairs but don't rush into anything.
Post by: dbr on 07 January 2010, 13:00:25
i get the wont unlock problem if the passenger has lifted the handle on the outside. it does unlock eventually by doing an up / down motion on the lock on the inside. remote has no effect
