Omega Help Area => Omega General Help => Topic started by: Shackeng on 11 January 2010, 19:05:41
Title: Seat removal
Post by: Shackeng on 11 January 2010, 19:05:41
Is there anything tricky, other than isolating the seat belt tensioning system, about removing a drivers seat?
TIA :y
Title: Re: Seat removal
Post by: TheBoy on 11 January 2010, 19:09:12
Side airbag!!
If that pops on your chops, that'll smart in the morning ;D
As you have already said, also pretensioners - you'll chew your smalls if that goes off
Post by: Welung666 on 11 January 2010, 20:36:56
Disconnect the battery for an hour before you start and leave it off until the seat is reconnected. 3 plugs near the sill and 4 torx bolts and it's out :y
[edit]And FFS don't drop it when it's out as it's heavy![/edit]
Post by: Shackeng on 11 January 2010, 23:03:31
Side airbag!!
Can't find it in Haynes. Help please
Welung666 wrote
Disconnect the battery for an hour before you start and leave it off until the seat is reconnected. 3 plugs near the sill and 4 torx bolts and it's out Thumbs Up!
Edited:
Thanks very much :y :y :y
Post by: Entwood on 11 January 2010, 23:13:24
If you have electric seats undo the 4 bolts before disconnecting the electrics, as you need to motor the seats to get access !!
Then disconnect the battery, make a cuppa, read the paper, before disconnecting the seat plugs ...
Post by: Shackeng on 12 January 2010, 10:55:56
Thanks Nige,
Non electric :(, but would like to know about isolating side airbags, I am hoping to repair the seat heating, as PedroMV6 suggests that it can be done on leather seats. :-?
Post by: Shackeng on 12 January 2010, 12:57:04
Side airbag!!
Can anyone amplify this please? Disconnection/isolation whatever?
Post by: unlucky mark mv6 on 12 January 2010, 14:38:45
Thanks Nige,
Be sure to let us know if its doable mate,as mine needs doing. :y
Post by: Elite Pete on 12 January 2010, 14:49:32
Disconnect the battery and leave it for 15 mins before you pull any plugs at the side of the seat.
Post by: joshwyatt on 12 January 2010, 14:52:58
Side airbag!!
If the battery is disconnected that's good enough, you don't need to do anything else. As said previously, leave it disconnected for an hour before you attempt anything. But, make sure you do not let the battery connecter thing touch the terminal. The bit you disconnect, put it in a cloth or wrap it in a bit of cardboard. As if it touches the battery terminals the air bag light will come on if the seat is unplugged.
Also raise the seat to the highest position to make it easier to get to the bolts out.
Post by: Shackeng on 12 January 2010, 17:04:39
Side airbag!!
Thanks a lot Josh, I had'nt connected the fact of battery diconnect/waiting time with the airbag. All is now clear :y :y :y
Post by: Shackeng on 12 January 2010, 17:06:34
[/quote]
Be sure to let us know if its doable mate,as mine needs doing. :y[/quote]
Will post it up IF and WHEN I get around to doing it, more serious things to do first :y
