		Omega Help Area => Omega General Help => Topic started by: Eric DUBLIN on 18 January 2010, 08:27:41
				hi to all! injector at front of engine losing air at base! can this be pulled up?????
 to all who advised on pump change/belt etc! i will post follow up real soon!  thanks again!    Eric
				needs a new copper seal I guess...
				Check that your leak-off pipes are intact, and also that the injector pipe is tight.
				Copper seal sounds right as its coming from the base of the injector !  can i solve this issue myself ? is it handy?    i will post photo as soon as possible!
