Omega Help Area => Omega General Help => Topic started by: mantahatch on 23 January 2010, 15:17:05
Title: Heater fan won't switch off
Post by: mantahatch on 23 January 2010, 15:17:05
Hi Chaps, just given the car a run, and switched off as normal, and the climate control blower fan won't switch off.
It usually runs for a few seconds after switch off, but this is constant, have pulled the big 30 amp fuse under steering wheel and this has stopped it but I do need a permanent solution.
Thanks in advance.
Oh yes should add the I cannot change the speed of the fan via the buttons.
Title: Re: Heater fan won't switch off
Post by: sexydaz on 23 January 2010, 16:07:43
fanny speed regulator,some call it the hedgehog.go in the car spares area of the site and pm one of the breakers should only be about a tenner :y
Post by: mantahatch on 23 January 2010, 16:10:08
Thank You  :)
Post by: robson on 23 January 2010, 20:44:44
Had this problem myself recently Bought a new hedgehog on ebay for about £60.00. Be very careful when you take the old one out I did it during the cold spell and the retaining clips broke off. Out of interest how many miles has your car done.Can you think of a more stupid design that a failure means the fan keeps running with the ignition off.
Post by: Matchless on 23 January 2010, 23:47:14
Check the drain at the bottom of the nearside scuttle, if blocked rain water gets into the heater blower and causes the electronic fan speed controller to fail.
Post by: mantahatch on 24 January 2010, 17:08:37
Yes does seem odd to fail that way, I am buying a second hand one off the forum. I have removed the old one and fortunatly the lugs have not broke.
Post by: mantahatch on 24 January 2010, 17:10:11
That is one of the jobs I regularly do, and after removing it it is bone dry with no sign of any problems so I suppose it is an internal fault, Thanks for the suggestion though.
