Omega Help Area => Omega General Help => Topic started by: ronnic on 24 January 2010, 13:36:17
Title: Powered Steering noise
Post by: ronnic on 24 January 2010, 13:36:17
Hi guys,
hi have an 02 omega estate cdx auto. when the steering is on almost full lock there is a strange noise which has just started. the steering feels sort of juddery as well. I have checked the manual as I thought it might be low on powered steeering fluid. However I can't find any mention of if and where to top it up in the manual. :-[
Can any of you guys first tell me if it takes any kind of fluid for the steering and if it does where is the top up cap.
Your help is much appreaciated.
Title: Re: Powered Steering noise
Post by: mark.adams on 24 January 2010, 15:07:16
Does the noise sound like chewbacca from star wars?
Post by: ScottieMV6 on 24 January 2010, 15:35:52
I had the same problem and it was caused by running the engine with no power steering fluid in the reservoir. I ended up changing my power steering pump.
The reservoir is the thing with the red box round it in this picture
(http://i549.photobucket.com/albums/ii371/scottie7275/v6enginebay-1.jpg)
Post by: ronnic on 24 January 2010, 16:48:49
Hi Mark, yes it does sound a bit like the noise you described.
Thanks for pointing out where the resevior is on the omega Scottie. there is no mention of it it the manual. Tel mel will any power steering fluid do the job or is there a specific type i need.
cheers
Post by: ronnic on 24 January 2010, 16:57:57
hi guys I've just checked the resevoir and it is a lttle down, but i can't see any markings on the outside to gauge weather it needs a top up. can you tell me if it should be right up to the top or whereabouts the level should be. Many thanks guys.
Post by: ScottieMV6 on 24 January 2010, 17:21:15
Markings are on the dipstick which is part of the lid :y
Think you have to use ATF fluid from memory?
Post by: ronnic on 24 January 2010, 18:38:49
Cheers Scottie,
thanks foryour help
Post by: mark.adams on 24 January 2010, 19:07:54
If the fluid is ok and not low, its a weak power steering pump, quite a common fault on this model.
Mine does the same. You can replace the pump but i understand its a bit of a pig to do.
Post by: ScottieMV6 on 24 January 2010, 19:16:51
I didn't find it too bad. Apart from losing one of the bolts that holds it in, it was a fairly easy job :y
Post by: feeutfo on 24 January 2010, 22:41:25
does seem to be the common failure with pas on the omega, the pump is suprisingly small.
the fluid is dexron 2 for pas  (not dexron 3 which is for the gearbox and dont let any parts man tell you differant)
