Omega Help Area => Omega General Help => Topic started by: Dingleberry on 16 January 2010, 11:11:11
Title: Xenons Q
Post by: Dingleberry on 16 January 2010, 11:11:11
If an Omega has the headlight washers fitted, does this mean that it definately has xenons fitted ?
Cheers  :y
Title: Re: Xenons Q
Post by: Jimbob on 16 January 2010, 11:12:22
no.
Early (pre 1998) Elites had Halogen lights with washers.
Apart from that, only factory fitted to those with HID's (Xenon's)
Title: Re: Xenons Q
Post by: Dingleberry on 16 January 2010, 15:14:11
And the pre 1998 halogens would have had the projectors aswell ?
Title: Re: Xenons Q
Post by: Varche on 16 January 2010, 15:18:03
Mine is a late 97 Elite with Xenons and headlight washers. At least I presume they are. Blueish light? How can you tell?
Title: Re: Xenons Q
Post by: RobG on 16 January 2010, 15:18:37
I might be wrong :-/ but I think projectors were fitted as standard on the mini facelift, circa 97/98
Title: Re: Xenons Q
Post by: RobG on 16 January 2010, 15:19:56
If they are HID`s you won`t have the manual adjuster wheel on the lefthand side of the lighting switch. And when switched on there`s a slight delay to full illumination due to ballast powering up
Title: Re: Xenons Q
Post by: Varche on 16 January 2010, 15:25:05
No manual adjusting wheel, slight delay. HIDs they be.
Title: Re: Xenons Q
Post by: Dingleberry on 28 January 2010, 13:18:46
Sorry to bring this back up. Yet another Q
The plug that plugs into the ballast pack, when the headlights are switched on does this supply a permenant 12v to the ballast pack ?  :y
Title: Re: Xenons Q
Post by: TheBoy on 28 January 2010, 19:04:35
1998 model probably (last LETTER of VIN = W)
