Omega Help Area => Omega General Help => Topic started by: kcl on 02 February 2010, 10:02:19
Title: 3,2 with 5-speed auto box
Post by: kcl on 02 February 2010, 10:02:19
Does anyone have any idea what is the story with some Opel Omega 3,2 having a five speed automatic gearbox? What is the gear box model? I think it is not the same as in some diesels? Which cars were fitted with that box and why? Some 3,2 have "normal" 4-speed AR35 but some of the latest models seem to have 5-speed...
Title: Re: 3,2 with 5-speed auto box
Post by: tunnie on 02 February 2010, 10:03:57
never seen the 5 speed fitted to UK Omega's rumour has it some of the very very, very! last ones had it, but never come across one.  :-/
More popular in Europe though
Post by: fingers21 on 02 February 2010, 11:02:37
Mines a uk model 53 plate and has a 5 speed auto box. Not sure if its 4 speed with overdrive or what, but definately changes through 5 gears.
Post by: Andy B on 02 February 2010, 11:34:47
If you have D 3 2 1 it's a 4 speed with lock-up in 3rd & 4th  :y  :y
Post by: zirk on 02 February 2010, 12:49:51
Didn't the late Opel 2.5 24v Dti have 5 speed box's as standard, may be some late 3.2 opels got them?
Post by: tunnie on 02 February 2010, 12:50:57
Wish the UK got that lump instead of the 2.2  :(
Post by: zirk on 02 February 2010, 12:55:32
Agreed, a tunning box on one of those brings it up to about 200bhp  :y
Post by: Road Hog Mad on 02 February 2010, 12:56:48
what does the tuning box do to a 3.0 mv6? :D
Post by: tunnie on 02 February 2010, 12:57:48
Not as much, as there is no turbo to fiddle with
Post by: zirk on 02 February 2010, 13:04:23
If you Chip it, about 10bhp, 20 if your lucky, both mine are chipped, not much difference, slightly better Mpg in snail mode.
Post by: Kevin Wood on 02 February 2010, 14:33:15
It's easy to interpret the torque converter lockup as an additional gearchange on the 4 speed models. I didn't think any Uk models got the 5 speed gearbox. :-/ (it was a GM 5L40 gearbox IIRC)
If you have got a 5 speed 3.2 (which will indeed have PRND4321 on the gear selector), then...
<MontyPythonQuoteMode>You lucky, lucky batsrad! </MontyPythonQuoteMode>
 ;D
Post by: Martin_1962 on 02 February 2010, 18:27:08
 ;D
PRND432 look in gallery for the car concerned - quite along time ago
Post by: VXL V6 on 02 February 2010, 20:09:25
Was Hans-V6's car.
Got a picture of the selector but not on my home laptop at the moment.
Post by: TheBoy on 02 February 2010, 21:02:30
5 speed auto only on Y25DT (never put in Vauxhall). This helped overcome the defficiencies of the ratios on the AR25 fitted to U25DT and X25DT engines.  But mostly done because the Y25DT would rip the AR25/35 to bits ;D
AFAIK, there is no map for the 4L40 on anything other than Y25DT, so even if someone did graft it on, it would most likely be far from ideal.
