Omega Help Area => Omega General Help => Topic started by: dragonlord on 02 February 2010, 13:45:38
any know how to get sensor the out of coolent tank
just changing tank onw from scrapy aint got the bit wire gos in so got to swap mine
do the screw in or are the a push fit dont want to snap it
just pull it, hold the bottle, pull :)
thanks looking from old bottel it looked like had to be turned right way
cool thanks just need a good yank
then snaped lol
The sensor in the coolant bottle (header Tank) doesn't come out.
To get a new sensor you need to buy a new or known good tank
A new tank will set you back £25.66 + VAT
Cheers
Andy
Cheers
Andy
Dont tell me tunnie is wrong again ;D
Cheers
Andy
Yup
Cheers
Andy
Yup
No, the sensor does come out, takes about 5 seconds. I should know, taken borrowed enough from ones in the scrappy
tunnie I dont believe a word you say any more, your wrong to much of the time, even if the censor does come out I still think your not reliable enough. I dont listen to your advice any more.
previous thread detailing how its fixed, and its removable.
http://www.omegaowners.com/forum/YaBB.pl?num=1264801772
Then stop reading my posts :y
No one is forcing you to ;) ;D
Bit hard not to really, you seem to be all over this forum like a rash.
Cheers
Andy
Yup
It does come out - in bits ;D ;D ;)
Cheers
Andy
Yup
Snapped quite a few, TB has better luck removing them than i do. Trick is to wiggle it.
Worth doing as scrappy near me you can wonder around for free, and pop the odd sensor in your pocket. :D
Well someone can say thtat is shoplifting
Or when you think about the location it is scraplifting ;D
Cheers
Andy
Yup
That explains why there aren't any when I go to the Scrappy! >:( :P :D
yea they come out but what i done was court pcb thing and sliped sidways and shaped it as it came out
robing vx will only sell it with tank
so done me for neally 34 quid
lets just hope that fix the leak this time i knew it was leaking
but thort i was losing to much coolant for it to be just that
but when i pulled tank out was well wet underneath it
hbv had poped already so new one still ok
Cheers
Andy
Yup
See your local, you go to Smiths of Bloxham?
Cheers
Andy
Yup
I suppose you could get it out in one piece. Then it would probably leak, or not work. all to save 30 quid.
They do (unofficially) plug out, though its critical you pull them out straight, else you'll snap pcb.
About 1/3 the ones I've pulled out (in one piece!) have had dry joints on either the reed switch or on the connector. Rest have been knackered switches.
Last tank I bought was £24 + VAT, and looks better than the manky older ones, so thats the route I'd recommend if you snap the switch ;D
You are of course entitled to your opinion. Hell, you may even be right. Or you could be wrong.
You have the right to agree or disagree with any post, but please try to do so in a more constructive way. Cheers :y
ok i confess :-[ :-[ :-[ your right about dry joint
i got it out saw the dry joint and it had a crack in pcb so i soldered it
went out side with it dropped and spent 10 min looking for it . then found it by putting a size 11 on it
