		Omega Help Area => Omega General Help => Topic started by: mr ICE man on 04 February 2010, 20:36:28
				Was looking in engine bay today and the egr valve on the engine Has a small black pipe conected to it but it doesn't look like it should be there should it have a pipe connected and if so what's the pipe for?it's on 2.5 BMW engine
 cheers!
				Some TDs have two small-bore pipes on the underside, some have only one pipe plus a vent hole.
 Whichever variant that you have, the outer (or only) pipe is connected to the boost sensor which is located on the nearside inner wing. It's a glass-topped filter, which is itself vented to the atmosphere. The small-bore pipe is very similar to that used for the leak-off pipes.
