Omega Help Area => Omega General Help => Topic started by: belfastmale45 on 09 February 2010, 13:57:48
Title: Thermostat
Post by: belfastmale45 on 09 February 2010, 13:57:48
Hi guys
Guess this is an easy one...but I would like to do it properly without damaging anything.  :D
How do I exchange an old Thermosat (not the housing) with a new one? Do I need a gasket? Do I need grease? Do I need any sealant?
I have a new thermostat with two thin rubber rings, a silver foil containing greases...and a jubliee ring.
I understand collant will be lost when I remove the hose connecting it to the top of the rad, but can it be collected in a container and reused?
Thank you in advance :y
Title: Re: Thermostat
Post by: Jimbob on 09 February 2010, 13:59:15
your engine type would be a help  :y
adding your car details to your profile makes things a lot easier  :y
Post by: belfastmale45 on 09 February 2010, 14:17:31
I thought I had already done that when I joined.
Will do again Thanks JB
Post by: belfastmale45 on 09 February 2010, 14:23:33
Ok Jb
Profile updated mate.
I drive an 1994 Omega 2 ltre Ed Select Estate Reg begins with 'R'
Post by: Tim7 on 09 February 2010, 17:20:26
Replaced mine a few weeks back, put a bowl under the engine to catch most of the coolent, take the hoses off remove the housing swap the 'stat put it back togeather using the new rubber seal, I used a bit of liquid gasket as well just to be safe. I checked the coolent I collected was free from contaminates and poured it back in, run engine upto temp and top up coolent when any air has worked its way out.
Post by: tunnie on 09 February 2010, 17:22:27
for the minimal cost (£17) its worth changing the coolant, as its poor coolant servicing is the biggest cause of HG failure on the 4 pots.
Post by: Marks DTM Calib on 09 February 2010, 17:26:17
8V or 16V 2.0?
Post by: belfastmale45 on 09 February 2010, 22:46:09
Sorry I always forget some part  :-/
It's an 8 V
Post by: belfastmale45 on 09 February 2010, 22:48:09
Tim, Tunnie
Thank you guys.
What is the grease for that came with the new stat?
Silly question I know, but I've never replaced a stat before on my own.
Post by: belfastmale45 on 10 February 2010, 22:01:24
Replaced the thermostat today and also put new coolant in, I didn't bother saving the old coolant that came out when the old stat was removed.
Result is HEAT in cab once more.
So thank you guys for all your help.
MOT is supposed to be two weeks from now..
