Omega Help Area => Omega General Help => Topic started by: jpg1221 on 12 February 2010, 16:11:47
Title: wiper jets not working please help !!!
Post by: jpg1221 on 12 February 2010, 16:11:47
hi there could anyone tell me how to fix my jets ??? when i pull the stalk towards me to wash the screen nothing comes from the jets. i have checked screen wash and yes it`s full. has anyone any suggestions ?????? many thanks  :y
Title: Re: wiper jets not working please help !!!
Post by: Chris_H on 12 February 2010, 16:15:33
CAn you hear the pump buzzing?  If not then fuse or pump or wiring.
If it is buzzing then you probably need to clean the rubber filter that is on the pump pickup.  Reverse-flushing with a hose or kitchen tap is best but be careful taking the pump out (it pushes in) as you can break the exit tube.
Post by: jpg1221 on 12 February 2010, 16:18:00
nice 1 thanks chris, i can`t hear any buzzing so to narrow it down it must be wiring or fuse. i will re-check the fuses and take it from there. ;D
Post by: tunnie on 12 February 2010, 16:25:15
to double check the pump get a bottle or cup of water, take the motor out and pop it in the cup, see if it pumps / blasts water.
There is also a gauze in the washer bottle, when you take the pump out feel for a lip around the edge to the hole (ooo errr)
Pull this up, it often gets clogged and prevents water getting to the motor.
Post by: jpg1221 on 12 February 2010, 16:27:56
 ;D ;D ;D thanks very much am goin to try it now and see wot i can do. will let u know later on chaps. ty :y
Post by: jpg1221 on 12 February 2010, 17:46:59
right..... av had a look and can`t seem to find out wot the problem is  :'( i took the grill off, carefully pulled up the pump/motor and then grazed my hands in the process !!! so after much effin and jeffin i put everything back where it belongs and thought f*&k it. as u can tell i`m not mechanicaly minded. but thanks for all ur help anyway, looks like goin to a garage to av it put right.
Post by: tunnie on 12 February 2010, 17:53:55
where in the country are you? a member near you might be able to help  :y
Post by: jpg1221 on 12 February 2010, 17:58:50
i`m from barnsley, but only available weekends.  ;)
Post by: davethediver on 12 February 2010, 18:09:17
right..... av had a look and can`t seem to find out wot the problem is  :'( i took the grill off, carefully pulled up the pump/motor and then grazed my hands in the process !!! so after much effin and jeffin i put everything back where it belongs and thought f*&k it. as u can tell i`m not mechanicaly minded. but thanks for all you are help anyway, looks like goin to a garage to av it put right.
Most of us start out that way, but with help off this site and some of the fantastic how too's you'll get there  :y
Post by: dbr on 12 February 2010, 18:36:12
If not motor look for a fold in the pipe where it goes into the bonnet. Happened to me.
Post by: Andy B on 12 February 2010, 18:38:01
Remove the pump from the bottle, be ready to stick a pen in where you've just removed the pump from if you want to save your washer fluid!  ;)
Try putting 12 volts across the 2 terminals. It doesn't matter which way round if you're testing and see what happens  :-/ If it doesn't work you've found the problem, if it does ... then your problem is elsewhere  :y  :y
Post by: jpg1221 on 12 February 2010, 18:38:55
thanks ever so much gents i will give it another go 2moz and let yall know.  :y
