Omega Help Area => Omega General Help => Topic started by: unlucky alf on 16 February 2010, 12:18:48
Title: TD no4 injector dilemma
Post by: unlucky alf on 16 February 2010, 12:18:48
o,k i received my replacement injector this morning, the problems ive got is: 1/ its got a black plug & mine is white. & 2/ the locating lug on the new one is in a different position, other than that the plug looks the same as the pins are marked up 1&2  the same as mine, is there a reason why the plug setup has been changed or can i just cut the locating lug off so it goes in. :-/
Title: Re: TD no4 injector dilemma
Post by: Welung666 on 16 February 2010, 12:24:34
You should, if very careful with a pin, be able to remove the plug cover and swop it over to the original so it fits properly.
Post by: unlucky alf on 16 February 2010, 12:44:58
i did think of that welung but the wires are well sealed in the top of the plug, ive cut the lug off the plug now & marked the plug so i get it the correct way round, it still bugs me why the plug is slightly different, im just hoping its vx being awkward & not the fact that maybe the chip in the injector is set up differently, oh well id better go & try it, time to get my arm cut to bits getting it to plug in as its a swine to get to. :o :o :o
Post by: Marks DTM Calib on 16 February 2010, 13:10:26
I guess you have the pre-maf diesel setup....
Post by: unlucky alf on 16 February 2010, 14:36:20
yup you got it mark,do you know if the plug is the only difference between the two?  it plugged in o,k after lobbing the lug off the plug & it starts & runs o,k,so please tell me other than the plug they are the same injector,,,,cheers :y :y
Post by: Marks DTM Calib on 16 February 2010, 14:53:07
Well, given its only a piezo transducer you are probably ok...should work fine
Post by: Turk on 16 February 2010, 15:43:04
I had the same issue and trimmed the lug off. Been running it for about 2 years now, no problems.  :y
Post by: hoofing it on 16 February 2010, 17:30:27
yip injector the same :y
