Omega Help Area => Omega General Help => Topic started by: Richard A on 20 February 2010, 21:47:45
What are the symptoms of a fault with a cam sensor ?
Regards
Richard a
hard to start when warm is one of them, but they are bullet proof on the V6
engine turns over but wont start. can be intermittent.
That's exactly what is happening, problem was there from the first start after a new cam belt was fitted.
Sometimes (most) engine turns over but does not start, but always starts on the second stroke of the key.
3k since cam belt replaced (excellent job) but no problem before.
The engine runs better than ever apart from this start problem.
regards
richard a
more likely crank sensor on V6, get the codes :y
Thanks but not the same as crank sensor, changed two, latest 6 months ago, different symptoms, now just the starting problem.
regards.
richard a
regards.
richard a
Crank sensor changed twice? Latest one is it pattern or genuine, how was the cable routed?
Both genuine, 70k between changes, routed away hot and cold things, cable, connectors look fine.
regards
richard a
