Omega Help Area => Omega General Help => Topic started by: l.t on 01 March 2010, 08:49:35
hi my climate control on my 99 2.5 manual sometimes works ... nice and warm , go on a run its fine . stop the car and get back in and its just cold air. any ideas?
cheers
l.t
does the sampling fan work ok?
there is a little 'vent' on the climate panel, when working it should be powerful enough to hold a small piece of tissue to itself.
If not, the car may think it is hot enough already, so not supply hot air...
sometimes a clean helps, otherwise the fan can be replaced with a small pc fan.
Is the blower working ok ? responsive to fan speed settings . Do any vents blow warm , Check L/H dash vent . I recently had one of the flap control linkages fail , but as yours seems to be intermittent that doesn't seem so likely but may be worth checking
