Omega Help Area => Omega General Help => Topic started by: deejaywardy on 26 February 2010, 23:47:32
Title: Help urgent :( , getting so annoyed
Post by: deejaywardy on 26 February 2010, 23:47:32
ok so my car still has a missfire on cyl 1 , 3 , 5 been told it could be a few things like plugs and coil pack ,, changed the plugs and did the coil pack today and its still missfireing
im so pi**ed off with the car now its costing me so much and its still not right ??
can anyone help please ??
thanks so much Ben
Title: Re: Help urgent :( , getting so annoyed
Post by: goonv6 on 26 February 2010, 23:50:07
Definately sure you've connected the leads up correctly and did you use a new DIS?
Post by: rustym95 on 26 February 2010, 23:50:19
did you get a new dis pack? check the plug on the wire make sure that it good and clean. also check the ecu main plug is in tight. and injector relay.
Post by: deejaywardy on 26 February 2010, 23:53:14
yeh brand new bosh one ,, connecter looked nice and clean to me ,, so lost as what to do as i need the car for work and its just costing me so much to fix but nothing is going rite ,,
would it make any difference if i put the code reader on it and clear the errors becasue when i checked it a while ago it said miss fire etc but never cleared error memory when i fitted new bits ??
Post by: tunnie on 26 February 2010, 23:55:55
No leads on 3.2 its coil pack  ;)
Do a pedal trick and post up the codes  :y
Post by: rustym95 on 26 February 2010, 23:56:20
dose the eml light still come on, or is it off?
Post by: tunnie on 26 February 2010, 23:56:40
out of interest, do you have K&N panel or cone filter fitted?
Post by: tunnie on 26 February 2010, 23:57:19
How about the leads themselves? They may look new but the could be brittle on the inside.
There are no leads on 3.2 or 2.6
Post by: deejaywardy on 27 February 2010, 00:03:13
ill run the code reader 2mora and let you know all the codes ,, no its running standard air box and the eml is off , never came on just got the missfire
Post by: Rockhampton on 27 February 2010, 00:48:01
Sorry if I'm asking the obvious, but you don't have any water getting in there from the scuttle?? Took me ages to find it on mine (got there in the end thanks to Tunnie  :y) although mine was on the other bank.
Post by: feeutfo on 27 February 2010, 06:14:45
thanks so much Ben
where are you getting the missfire info? from the pedal trick? or code reader? exactly what codes are you getting?
 missfire codes start p030* iirc
Post by: feeutfo on 27 February 2010, 06:30:23
you can read the codes yourself here,
although you do need a code reader to clear them.
Post by: dave10 on 27 February 2010, 08:50:36
spray the leads both ends with wd40 to make sure they are not arcing across each other
Post by: RobseyMV6 on 27 February 2010, 09:24:58
Mate, there are no leads on 3.2
Post by: tunnie on 27 February 2010, 09:42:40
Third time lucky?  ::)  ;D
Post by: MaxV6 on 27 February 2010, 10:38:01
so how does the DIS-Pack get a spark to the plug with no lead????  (seriously.... ????? I've not yet owned a 3.2 so have no idea how different it is....   )
Post by: tunnie on 27 February 2010, 10:49:57
There is no DIS pack, there are coil packs which sit above each bank, the 'lead' is part of the coil pack:
This is a 4 pot version for the 2.2:
(http://www.rinis-automotive.com/shopimages/products/thumbnails/CU1000-FINAL.jpg)
Post by: Andy H on 27 February 2010, 10:50:31
One coil per plug.
The dis packs on the 2.2, 2.6 & 3.2 are a strip of plastic wth 3 (or 4 on 2.2) little ignition coils that sit on top of each of the spark plugs.
When in place it just looks like a cover strip down the middle of the cam covers.
(http://images.omegaowners.com/images/guides/v6_plug_change/140he.jpg)
Post by: tunnie on 27 February 2010, 10:51:12
Booo your diagram is better than mine  ;D
Post by: Andy H on 27 February 2010, 11:35:05
It isn't mine ::) I copied it from the maintenance guide  :y
Post by: MaxV6 on 27 February 2010, 12:10:21
so now i get it.... clever....  i presume it's less prone to corrosion fromm leaky things like HBV and stuff then?    reliability improvement????
Post by: tunnie on 27 February 2010, 12:55:15
Err well not really, they don't seem to be any more reliable, heat is a problem i think for them. I replaced mine at 105k
Post by: Grrrrrr on 27 February 2010, 14:46:09
Could it be that the idea is that since it is essentially low-tension right up till the last minute the leads won't wear out and therefore you don't have to get burnt trying to shove your arm up past the exhaust to fiddle blind with the DIS pack from h*ll?
Post by: manny on 27 February 2010, 19:01:14
What is problem with these filters.
Post by: tunnie on 27 February 2010, 19:19:45
Panel filters are oiled, and kill the MAF.
Cone filters are just plain stupid, they reduce power, suck in warm air rather than cold and actually reduce performance
Post by: Andy H on 27 February 2010, 23:21:04
I think oiled filters are available as either panel or cone filters.
They can work well with carburetors or throttle bodies but they mustn't be used with a MAF because particles of oil can get carried over to the MAF sensor and contaminate it.
I agree that the standard air intake should get cooler air than a cone filter would but I don't know if it will make that much difference if the car is moving :-/
Post by: deejaywardy on 28 February 2010, 09:06:46
thanks for all the replys everyone ,, i read the codes on a code reader dont remember the numbers now but it said missfire cyl 1 , 3, 5 , car must of been running in limp mode ,, i cleared the error codes and car seemed to run alot better then  ,,, i took it for a long drive yesterday and all was fine till about 20mils down the raod it went back into limp mode again and started to missfire ??? anyone have any ideas ??? im thinking the plugs or one of the plugs on 1,3,5 could be faulty ?????
Post by: Welung666 on 28 February 2010, 10:00:33
I've had this on one of my classic cars, all new ignition components and still had a misfire. turned out to be the small silver cap on the plugs were loose so they weren't allowing a full spark through. Tightened them with pliers and all was well again. Not sure if that's it but an easy one to rule out ;)
Post by: deejaywardy on 28 February 2010, 15:45:41
ok so got some more new plugs today got them fitted went for another test drive and still missfires ??? so all in all ive done cam cover gaskets , spark plugs twice , coil pack , cleaned the MAF ,,, and there is still a missfire on cyl 1,3,5 ,, what else could it be im at my wits end and just feel like getting rid of the dam thing lol
ben
Post by: deejaywardy on 28 February 2010, 17:00:50
checked the bits on end of plugs they are tight  :( so still no idea what it is ????
Post by: PhilRich on 28 February 2010, 17:16:16
when the plugs were out, did you notice any oil or water contamination anywhere? Are the ends of the coil pack rubber plug covers ok, or showing signs of wear, breakdown etc? :-?
Post by: deejaywardy on 28 February 2010, 17:39:26
yeh when i first looked it had oil on them but i done the gaskets and everything nothing else seemed wrong apart from that ,, so still dont know ??
Post by: deejaywardy on 28 February 2010, 21:57:00
i give up with it lol costing to much money ,, anyone want a 3.2 omega specail with LPG
£1500
Link Here :-  http://www.pistonheads.com/sales/1525063.htm
Post by: feeutfo on 28 February 2010, 22:42:04
do pedal trick
read codes
post codes
Post by: deejaywardy on 28 February 2010, 22:43:08
had it on the diagnostic and its just says missfire cyl 1 3 and 5  :(
Post by: feeutfo on 28 February 2010, 22:46:36
are you winding me up?
Post by: deejaywardy on 28 February 2010, 22:47:37
no why ??
Post by: alunonhisown on 28 February 2010, 22:47:38
Someone help this kid before he does something drastic.
I was helped when I was feeling like he is.
Come on folks
James Elite Pete  Daz, try and help the kid, he must be at his wits end to put it on Pistonheads.
Post by: feeutfo on 28 February 2010, 22:49:08
trying, refuses to be helped
for the last time
do the pedal trick
Post by: Entwood on 28 February 2010, 22:50:01
Methinks a quick trip from Grantham to Nottingham so MarkDTM can put a tech2 on it and get some live data is the first step.
There is no point in changing parts willy-nilly and in hope ... the rules are simple ..
Diagnose
Rectify
Nowhere in there is the word "guess"
Post by: deejaywardy on 28 February 2010, 22:50:02
oh yeh i am im so fed up with it now ,, spent so much money getting the clutch done :( now this ,, spent a fair bit trying to fix this problem and nothing ,, so ive about had it lol
Post by: Cliffo B on 28 February 2010, 22:51:10
Or Dispack!! :y
Post by: Entwood on 28 February 2010, 22:53:12
Or Dispack!! :y
Its been said before .. I'll say it again .. LOUDLY
[size=16]3.2 V6 ENGINES DO NOT HAVE A DIS PACK[/size]
Post by: deejaywardy on 28 February 2010, 22:54:14
has a coil pack m8  :y
Post by: tunnie on 28 February 2010, 22:54:28
so new plugs are in, no oil in the wells?
Still getting 135 miss-fire? Points to coil pack.
Unplug the MAF, take it for a drive, if it still miss-firing. Its coil pack on 135 bank
Post by: tunnie on 28 February 2010, 22:55:46
Or Dispack!! :y
For the [size=20]4th[/size] time, it has no dis pack, its coil pack above the plugs.
Post by: Entwood on 28 February 2010, 22:56:31
actually has 2 Coil Per Plug modules if you wish to be totally accurate.
Do the pedal trick .. post up all the codes you get.
PM MarkDTM arrange to visit him for a live data reading
Stop guessing
Take car off pistonheads.
Simple  ......  :)
Post by: deejaywardy on 28 February 2010, 22:57:43
got a brand new coil pack on got it day before yesterday
codes
0300
0301
0303
0305
Post by: tunnie on 28 February 2010, 22:59:07
codes
0300
0301
0303
0305
Which bank?
Post by: feeutfo on 28 February 2010, 23:00:06
codes
0300
0301
0303
0305
is that from a generic reader? they often talk 'dangle berries'
Post by: tunnie on 28 February 2010, 23:00:55
0301
0303
0305
Earlier posts you did not give these codes? Only missfire on 135 bank?
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
Both coil packs will not fail, and as long as the plugs are clear of oil, if you getting miss-fire across both banks, suggests MAF.
Unplug it and go for a drive
Post by: feeutfo on 28 February 2010, 23:00:56
also does not explane limp mode
Post by: deejaywardy on 28 February 2010, 23:02:46
bank 1,3,5 pack ,,, yeh its off a bosh reader i have ,, ive cleared the erros before and it was fine for about 20 or so miles then started to missfire again ,, now does it offen even after errors are cleared
i would do the pedal trick but car is at my girlfriends house
Post by: deejaywardy on 28 February 2010, 23:04:31
yeh only missfire on bank 135
Post by: feeutfo on 28 February 2010, 23:09:39
bosch are shite, as are snap on.
often give conflicting info, they dont seem to have the complete code list ime
Strongly sugest pedal trick when possible. its free, to confirm accurate code read.
If still 0300 1/3/5 drivers side, check wiring and plug to coil pack (no dis pack or leads) for continuity or damage.
Post by: deejaywardy on 28 February 2010, 23:13:48
Strongly sugest pegal trick when possible. its free, to confirm accurate code read.
checked plug and cleaned it and wires and all seem fine ,, i shall go do the pedal trick 2morrow after work and see what i get and post results ,, i would drive the car to nottingham to see mark but as car is running like it is at the momet its drinking to much fuel and my pockets are a bit empty at the moment  :P
Post by: feeutfo on 28 February 2010, 23:24:06
ok, also check ucu plug fully home/no corrosion on the pins while your there.
if you have the same codes via pedal trick with new plugs and coil pack and good wiring, then as Entwood says, it needs teach 2 to investigate further, Mark dtm is nearest you, he is far cheaper and better than any garage.
Post by: unlucky mark mv6 on 28 February 2010, 23:25:34
is it possible the cats are knackered. :-/
Post by: feeutfo on 28 February 2010, 23:27:34
cant tell anymore without further diagnostic.
too much guess work going on here i'm affraid
Post by: webby23 on 28 February 2010, 23:33:10
Whats Grantham to Nottingham?
30 miles.....??
I do it in 45 mins in my 18t truck at 40mph all the way along the A52, so I would say its a 30 min drive in a Mig.....
People are trying to help you buddy but you got to want to help yourself too.....
Post by: goonv6 on 01 March 2010, 00:37:45
Did you say with LPG? What plugs have you put in? I think the MAF idea may be plausible too. The other thing that is ringing in my mind is whether the timing belt has jumped a tooth. You'd get erratic running but I don't know whether it would register as a misfire.
Also,I wish you'd stop bloody quoting me. I deleted the second post straight after the first as I realised it was a mistake and Tunnie had already flipping quoted me. :D
Post by: feeutfo on 01 March 2010, 01:21:12
:P ;)
Post by: feeutfo on 01 March 2010, 01:28:53
how would maf fault affect one bank though? and would expect a fuel trim code if so...?
belt issue possible but why would it clear when codes cleared and then play up again after 20miles, or whatever it was?
cat issue would also raise a code imo
Post by: feeutfo on 01 March 2010, 01:34:43
should also ask if any other work has been carried out that may have had an effect on the issue?
Post by: ians on 01 March 2010, 17:17:57
Just to question what may be obvious..
1,3,5 bank is on the drivers side (right hand drive ;)) - you did change that one didn't you?
Post by: Big_Roger on 01 March 2010, 17:31:22
Hi,
I have been following this thread with some interest, as this was the first problem I had when I bought my car.
I don't think I can add any thing much to what has already been said.
When I had this problem, my code reader identified which cylinder was miss firing, on examination you could see the cracks and iron laminate swelled on that plug unit.
What puzzles me is your 0300 multi cylinder misfire.
I would be looking for bad earth connections on supply to CPP unit or on the injectors on 1-3-5 bank.
I don't like making guesses, but it does sometimes happen that a new / replacement part is faulty.
Roger
Post by: deejaywardy on 01 March 2010, 18:08:31
well ive checked a few things over today and all seems fine really ,,, been for a drive today with the MAF unplugged ,, drives well now ,, after a few miles it did go into limp mode again and missfired so i stoped the car and restarted and was fine again ,, so it coul be my MAF that is no good ,,, but i think it is something else aswell as the MAF  ??
yeh 135 is drivers side and thats the side ive done all the work on  :y
