Omega Help Area => Omega General Help => Topic started by: megaomega123 on 01 March 2010, 17:15:09
Title: Aux tensioner again
Post by: megaomega123 on 01 March 2010, 17:15:09
Is the bolt that holds the pulley on supposed to be loose? It moves back and forth in the tensioner by about 10mm. Obviously it tightens when the pulley is on and tightened up. Just checking.
Title: Re: Aux tensioner again
Post by: Andy B on 01 March 2010, 17:23:42
Yes, until you tighten it up!  ::)  ;)  :y If you were to remove the whole tensioner from the side of the block, the bolt would fall out.  :y
Post by: megaomega123 on 01 March 2010, 18:15:58
Thanks very much  :y
