Omega Help Area => Omega General Help => Topic started by: Varche on 03 March 2010, 15:19:16
Title: Heater matrix quick release clip question
Post by: Varche on 03 March 2010, 15:19:16
I am trying to get these off. Have removed the scuttle for slightly better access.
Following the guidehttp://www.omegaowners.com/forum/YaBB.pl?num=1185891036. It all looks straightforward. BUT    :-[
I have moved the fitting half an inch along the top pipe but that is it. A green plastic 3/4 circular ring with 3 shapes on it dropped out. Does this need to be back in for the quick release to operate.?
also how do you press the latch in? small screwdriver in the 1/8th inch hole or pressing down on the bit with three grooves.
My plan is to insert a short length of pipe to bypass the heater matrix to "prove" it is leaking.
Title: Re: Heater matrix quick release clip question
Post by: Jimbob on 03 March 2010, 15:23:27
dont worry about the green bit, its from production and can be discarded  :y
just pull the latch into the hose, wiggle, twist, and off it comes
Post by: Varche on 03 March 2010, 16:06:04
Excellent. Job done. Thanks!! :) :) :)
Post by: Jimbob on 03 March 2010, 17:32:26
