Omega Help Area => Omega General Help => Topic started by: alfie on 08 March 2010, 18:34:10
Hi Everyone,had the dreaded pink mot failure form today.
The failure was down to the near side steering idler,fair do,it was knacked heaps of play.
Are they a problem to replace,and any of you recommend where to get one from.
Alfie.
common failure, check maintenance guide section for details, get decent Vx part, don't bother with cheap patterns
no real problems just get a full one not just the idler, its held on by 2 bolts, and take of the joint comes off easy with the right tools. price varies from £30 -£60 for a full one. but get a proper one not a copy.
Easy enough job... This is the recommended part :y :y
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190371926619
Hi,thanks for the ad,looking for a o/e last night but missed that one,all in all had a bugger of a week.
Alfie
I got mine from www.aoutovaux.com Never had any problems with it. and only paid £26 with delivery.
you could try them.
This is the part I've just fitted, delivered quickly as well.
Yes easy enough job, when you've bashed the hell out of the b****y thing with a sodding great lump hammer, to get the joint apart :-[
Don't use a ball joint splitter on that knuckle joint, some say two hammers will do the trick top and bottom. Soak in plus gas overnight if poss before attempting :y
Mick ;)
Hi,Just a quick update,failed to part the ball joint after a few hours of trying everything.
So I bit the bullet and found a garage to do it,cost £15 so I was quite happy with that,so retest in the morning,and then of to Brean in the van for the weekend.
Alfie.
That's the tapered joint from hell!
I always give it a good clout by hitting it hard with two hammers simultaneously.
Haven't failed yet mate!
