Omega Help Area => Omega General Help => Topic started by: Sir Sideways on 07 March 2010, 19:43:01
Just done the above conversion as on the how 2 in the maintainance guides. This is just a note the admin may want to add.
The housing body was not held on by a 27mm nut, it was a 12mm allen bolt instead.
I ended up sawing the end of a 12mm allen key off to fit in a 12mm socket for extra leverage as it was very tight.
Jim
Not mine; it was just as the guide here said, a 27mm hollow bolt (the cap was 24mm though):
http://www.omegaowners.com/forum/YaBB.pl?num=1204142232
Mines a facelift 3.0 if it makes any difference.
Yeah, that must be it.
Can anyone else comment?
I ended up sawing the end of a 12mm allen key off ......
Quite a soft allen key if you could saw it! ::) ;) :y
took about 20 mins with an hacksaw. Arm like Popeye when i'd finished.
I use an angle grinder for stuff like that. Or I would use a cutting tool that I don't have but would really like.
may I suggest ...... :y :y :y
(http://i.ebayimg.com/11/!BR4eGTg!Wk~$(KGrHgoH-DcEkJw1zHMKBK!VIhIG0Q~~_35.JPG)
I know what an "adage" is, http://en.wikipedia.org/wiki/Adage but what's an "addage" ?
Mind you, I know what an "addition" is. ::)
(ok, so I'm being a pedantic @rse, but it's STMO's day off !)
mine's a mini facelift and it also had the 12mm allen bolt.
That's weird; mine definitely had the 27mm hollow bolt.
Did the 12mm allen key fit inside your hollow bolt, or elsewhere?
It seems pretty random as to what fixing it has....I suspect there is 2 suppliers of housing
Mine's a 12mm on a 51 plate 2.6.
;) But you may be a pedant in both of Britain`s official State languages! ;D
...or maybe just an @rse. ;D
oh yes yer cant beat a nice skinny slitting disc..hot knife through butter
