Omega Help Area => Omega General Help => Topic started by: greenfinger on 15 March 2010, 22:23:06
Hi
S reg omega both rev counter and speedometer have
stoped stoped working has anyone any ideas of the cause
of this
"Hello" and Welcome :)
Try pressing firmly on the centre of the panel, between the rev counter and speedo ... firmly but without any jerking.
It is not unknown for the plug the panel connects to, to become loose, this may reseat it. If not its probably a clocks panel out job to reset the plug .. :(
Welcome to the forum :y
As kenwood Entwood says, it's not uncommon for the plug to work loose. Have you got any other symptoms/warning lights showing?
[edit]Stupid predictive entry on mobile phones[/edit]
Tends to be the right hand side of the clocks working loose as there is no screw that side...might be worth seeing if you can tighten up the centre screw once you have pushed the clocks backin place if it proves to be the solution (which I also suspect will be the case) :y
Tried what Entwood sugested worked for a few hours but have now stopped working again will try other sugestions
thanks for for your help :y
If that made it work for a while then you've found your problem... May need to remove them and re-fit to cure it :y :y
