Omega Help Area => Omega General Help => Topic started by: duggs on 18 March 2010, 10:28:14
Title: Small Water Loss ! Is it possible ?
Post by: duggs on 18 March 2010, 10:28:14
Is it possible to loose a small amount of water if the
cam gaskets are failing. I've certainly got oil leaks which are being dealt with tomorrow BUT i'm also loosing a little water/coolant also. A little being about half a litre every fortnight.
The oil sitting on top of the sump DOES look rather "watered down".
No mayo on dipstick or anything horrible in the expansion tank.
Title: Re: Small Water Loss ! Is it possible ?
Post by: tunnie on 18 March 2010, 10:33:55
Nope, no water is in the cam area, water is used for cooling.
How much are you loosing? Could be weaping oil cover plate, pin hole leak in the rad or weaping HBV.
Feel around the back for the HBV see if that feels damp, as thats the most likely cause of coolant loss....
Post by: duggs on 18 March 2010, 10:50:50
I'll have a fumble.  Will get Mr Mechanic to take a look tomorrow also. Apart from what I see as "watered down oil" I don't have a visable leak anywhere.
Thank you.
Post by: duggs on 18 March 2010, 11:08:07
Ok !  I've fumbled and the HBV is as dry as a bone.
As mentioned, I loose very little, about half a litre every 2 weeks. RAD seems fine BUT I'm 99% sure that there is water, not a lot, stuck on top of the sump, mixing with leaking oil from the cam gaskets.
Post by: MutantCav on 18 March 2010, 11:11:30
Mine is currently losing a little water occasionally...seems a twig has lodged in the aircon radiator and it leaks when at a certain angle on the curb!! Which is not really an issue as I normally park on my driveway lol :y
Post by: tunnie on 18 March 2010, 11:12:20
check the pipes into the heater matrix are ok, also take the black cover off that runs length of the top of the rad, check the main hose from there to the engine is ok, and not leaking. The pipe off the rad is plastic and are known to split if butchered....
Post by: david_omega on 18 March 2010, 11:16:59
if butchered.  i.e if has full main dealer history then! lol
Post by: duggs on 18 March 2010, 11:37:34
OOOOOO...thank you. Will have another fumble.
Haven't fumbled so much since my wedding night...sadly, 8 years on, thats an activity thats rather rare now a days.  Wonder if it's only me !
Post by: Abiton on 18 March 2010, 12:07:02
Water is denser than engine oil, so if there's any in the sump it should be at the bottom, not the top.
If you loosen the sump plug, and collect the first bit that comes out in a clear glass jar, you can see whether it looks more like coolant or just oil.  :)
Post by: duggs on 18 March 2010, 12:09:42
Doesn't appear to be any IN the sump..just ON the sump !
Post by: Lazydocker on 18 March 2010, 12:22:02
Duggs, I'll be finishing work at about 3... If you pm your address I'll pop round on my way home and have a quick look for you if you like? Can't stop long but a second pair of eyes may help :y :y
Post by: cmeonthemove on 18 March 2010, 12:23:58
Had a similar issue a few weeks ago with similar level of coolant loss. Try running the engine to operating temp, then leaving a tray under the engine as it may be a leak that's only apparent when the coolant is heated and under pressure. In my example it was a split rad pipe that only leaked when hot or when pressing on the pipe.
Post by: gstylebaby on 18 March 2010, 12:32:31
I've had a small coolant loss for well over 12 months and can i find it can i **** had in the garage to see if they could find and they car'nt. I'm gonna be ordering some u.v dye from the u.s if you car'nt find it let me know and i can order you one at the same time if you like you just have to get hold of a u.v light.  Was thinking about putting some kits together and putting them in the sale section but not syure if there are that many peeps that would want one?
Hope you get it sorted and i will be keeping my eye on this thread and trying the places peeps say myself. ;D ;D ;D :y :y
Post by: cem_devecioglu on 18 March 2010, 16:25:16
I discovered that my miggy looses from reservoir cap (old cap) when engine is hot, by pressure and evaporization.. (and I accidentally discovered that by listening the noises ;D)
Post by: gstylebaby on 18 March 2010, 17:19:33
Done that myself mate  :D and even when it was o.k changed it for a new one anyway  ;D ;D ;D
Post by: Abiton on 18 March 2010, 17:57:55
 :-[ Sorry, my misunderstanding.  Not having the best of days today.
Best of luck tracing the leak.  :y
Post by: Varche on 18 March 2010, 18:09:20
I had a similar problem for absolutely ages. In the end it is a problem with the heater matrix. Only found that out when I spotted water dripping from the a pipe above the auto gearbox. Proved it was within the car by dissing the heater matrix by inserting a short length of copper pipe in the heater cct matrix in and out pipes. Once you get the "quick release " connectors undone it is fairly easy to put a 4 inch bit of 15 mm copper plumbing pipe in. Mine has been running like that for a couple of weeks now while the replacement rad from Partsbuy arrives.
Post by: Andy H on 18 March 2010, 18:21:29
On both my Omegas corrosion has eaten away at the outside of the coolant transfer pipe where the radiator top hose fits.
The resulting pitting means that the hose doesn't really seal properly & the position of the transfer pipe makes it difficult to inspect. :(
Post by: Lazydocker on 18 March 2010, 19:26:45
Had a look today... There seems to be a little evidence of a leak at the HBV so advised changing it whilst stripped down for cam covers.
Then keep an eye on it. Other possibility is that the new WP (recently fitted) isn't seated properly :-/ :-/
Post by: duggs on 19 March 2010, 00:17:23
Got the new HBV sitting on the back seat already...chap has put the job off till Tuesday
Hopefully once the top's off...he'll find the leak.
Not the end of the world though as long as its not dripping on to the dispack. THAT cost me a fortune with my previous mig.
